Turn signal - Defender Source
Old November 28th, 2005, 09:52 AM
dfscott
Daryl Scott
1994 Defender
Turn signal
This is a turn signal lever question. I just purchased a 94. I've never so much as sat in a Land Rover before this purchase. When I move the turn signal lever to make a right turn (upward), the turn signal lever won't lock in place, so, to keep the right turn signal flashing, I must hold the turn signal lever upward or in place. The left turn signal position (downward) locks and works fine. Any suggestions? Daryl Scott
Old November 28th, 2005, 10:02 AM
Welcome Daryl! Yes it should lock in, you may need to replace it but it is pretty easy to get at to see if something is caught up in it. There are 4 screws holding in the bottom of the steering column, if you remove them you can take the top and bottom half's apart to get a look. DAP, Roversnoth, Northeast British parts or Atlantic British should have the switch if you need it.
Old November 28th, 2005, 11:00 AM
roverboy's Avatar
roverboy
Thomas
Booger
that part will cost you over $150 plus shipping if you buy it from Rovers North, or Atlantic British. I just replaced mine and I sourced it from the UK and it cost me $47 US delivered. Check e-bay, you might even find one cheaper that that.
"There is absolutely no excuse for the way I'm about to act."
Old November 28th, 2005, 03:01 PM
roverboy's Avatar
roverboy
Thomas
Booger
There's one on ebay right now for about $20...
Old November 28th, 2005, 09:41 PM
dfscott
Daryl Scott
1994 Defender
Can you provide me with the name of the UK Source? Thanks.
Old November 28th, 2005, 09:54 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I found that when mine was stuck like that it was just that the little piece which locks into place to hold up the turn signal was slightly worn/bent so that it wouldn't catch. I bent mine a bit and it has worked ever since.
If you don't find one on Ebay, Rovers Down South might have one cheaper than Rovers North.
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Turn signal in the bumper! Bowtracer Defender Technical Discussions 20 June 7th, 2005 10:18 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 05:19 PM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
