Turn Key but Engine Keeps Running - Defender Source
Join the Defender Source Community Today
Old July 1st, 2016, 02:15 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
So, yesterday I was meeting a buddy for beers and when I arrived at the bar I turned the Key to Off but the engine kept running. Very weird feeling BTW. I turned it back and tried again, no luck so I just stalled it and started drinking. Started back up just fine but when I got home I had to stall it again.
I've read about other folks having this issue with an early 110 Diesel and the advice they received was pull the lead off the stop solenoid. If it stops, then its an electrical issue, if it doesn't then its a mechanical issue with the solenoid.
Sound right/reasonable way to trouble shoot this thing?
Old July 1st, 2016, 02:21 PM
yep, pulling the wire is easier than using a meter.
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old July 1st, 2016, 02:22 PM
1of40's Avatar
1of40
1of40
Gracias
Old July 1st, 2016, 02:28 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
it's actually the fuel cutoff solenoid. Single wire on injector pump and grounds thru the solenoid...
Old July 1st, 2016, 02:36 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Clay, your motor is actually so happy to finally be running it's overriding your decisions...
Rent my
Old July 1st, 2016, 03:07 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Glad you didn't say blow by.
http://youtu.be/5zx3qKX_Pno
Old July 1st, 2016, 03:39 PM
1of40's Avatar
1of40
1of40
Clay, your motor is actually so happy to finally be running it's overriding your decisions... .
Exactly. She's absolutely scared of garages.
------ Follow up post added July 1st, 2016 04:41 PM ------
Originally Posted by down_shift View Post
Glad you didn't say blow by. http://youtu.be/5zx3qKX_Pno
yeah, simple single wire engines.
Old July 2nd, 2016, 11:56 AM
1of40's Avatar
1of40
1of40
Pulled the solenoid wire while engine was running and engine stopped. In hindsight the wire seemed a little loose.
Lightly sanded/cleaned the connections, reconnected. Whah-la! Back in business.
Old July 2nd, 2016, 01:25 PM
Pulled the solenoid wire while engine was running and engine stopped. In hindsight the wire seemed a little loose. Lightly sanded/cleaned the connections, reconnected. Whah-la! Back in business.
Awesome !
Old July 2nd, 2016, 02:30 PM
1of40's Avatar
1of40
1of40
Originally Posted by LostChord View Post
Awesome !
Yeah, seriously. Not that it's rocket science but I watched a YouTube on it and the guy was talking about how tricky it is to remove while in the truck and the abundance of caution re not getting dirt inside while removing it. My grin meter was pegged when all finally checked out this morning.
Old July 2nd, 2016, 02:33 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Be glad it wasn't a 300 setup with the tamper proof cover!
Old July 2nd, 2016, 02:35 PM
1of40's Avatar
1of40
1of40
Originally Posted by Z.G View Post
Be glad it wasn't a 300 setup with the tamper proof cover! Sent from my iPhone using Tapatalk
Yeah, read about that nightmare. Shear bolts and the whole nine yards. No thank you.
Old July 2nd, 2016, 04:06 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
It's not awful, just takes a while. I removed mine while doing the conversion
Old July 3rd, 2016, 07:52 AM
1of40's Avatar
1of40
1of40
It's not awful, just takes a while. I removed mine while doing the conversion Sent from my iPhone using Tapatalk
Right, during conversion is key. This poor guy was remote somewhere in Germany when shit hit his fan with just basic hand tools.
Old July 3rd, 2016, 02:39 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Can you post the link to the video you watched...my son just called from the road with his 200 TDI with the same issue. The fuel pump was just replaced so I'm thinking same issue. I'll search but wondering if you can post the link.
Old July 3rd, 2016, 02:41 PM
1of40's Avatar
1of40
1of40
Good Luck Bill
Old July 3rd, 2016, 02:48 PM
Bill Larson
Bill Larson
Thanks...he called me from the fuel station about 3 hours from Austin driving from Detroit...did it in two days. Pretty good for a 17 year old in a Soft top 87 ExMOD!! of course the heats gotta be killing him, lol.
Old July 3rd, 2016, 02:50 PM
1of40's Avatar
1of40
1of40
That's very impressive for a 17yo these days. Great life lessons though.
Old July 3rd, 2016, 02:59 PM
Bill Larson
Bill Larson
Yeah he did a 7 day trip with a buddy a few weeks ago for prep and has been on several expeditions. We did the Tejas to Alaska run last year so lots of miles on this kid. 1700 miles in a day and a half so I hope that this is the only problem...next week we caravan to New Mexico for 3 weeks and she goes to Roadside Rob's for updates, new trans, power steering and the like.
Old July 3rd, 2016, 03:05 PM
1of40's Avatar
1of40
1of40
Dave Bobeck and I were chatting about this yesterday. What you might tell your son to do is to give it a few taps with a flathead and a hammer. If the spring is gunk'd it may dislodge enough to get him on his way.
engine
HELP! Key won't turn past 1st position svxaddict Defender Technical Discussions 8 June 25th, 2014 01:44 PM
Turn-Key re-built engines. globallandrovers The Vendors Loft 22 June 9th, 2014 06:05 AM
Help! Cant get the key to turn over hotroddef90 Defender Technical Discussions 10 October 27th, 2012 03:51 PM
Ignition key won't turn! cgalpin Defender Technical Discussions 11 March 27th, 2010 05:42 PM
Turn the key and . . . CLICK! Bozman Defender Technical Discussions 15 January 25th, 2007 01:57 PM
