Turn Key but Engine Keeps Running - Page 2 - Defender Source
Old July 3rd, 2016, 04:27 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
yeah it's running so we'll deal with it when he gets here, probably pull it apart tomorrow and check it. He needs grit under those nails...
Old July 3rd, 2016, 11:23 PM
Bill Larson
Bill Larson
So small update because I haven't got into the problem yet...had to pop the clutch to stop the motor. Power was still flowing to the electric fan and dash, disconnected primary negative cable on the battery and was still energized, had to disco a secondary accessory cable (have no idea) to cut it all.
Old July 4th, 2016, 07:57 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
hmmm? Sure the key is turned off? It is a strange feeling to turn the key and not have the engine die. The first time it happened to me I turned the key back a couple times.
Old July 4th, 2016, 09:04 AM
Bill Larson
Bill Larson
Yeah thats the first thing I "double checked" of course I question any competency through experience with the workings on and in a Landcover...everything seemingly turns the "wrong way" or is on the "wrong side" so I'm always checking!
Old July 18th, 2016, 03:03 PM
FlyersFan76
1987 110 Convertible
FYI, there could be other issues. I have not researched everything that I need to do yet but I received these links.
Engine will not turn off? Fuel cut off solenoid stays on. How to fix. - Land Rover Technical Archive - LR4x4 - The Land Rover Forum
https://www.landyzone.co.uk/land-rov...rn-off.259062/
200 tdi won't switch off - Defender Forum - LR4x4 - The Land Rover Forum
The rear wiper switch is now my engine shut off switch. It works most of the time.
2011 Range Rover Sport
1987 Land Rover 110 Cabriolet
1997 Defender 90- AA Yellow #1701- Wrecked
1997 Defender 90- AA Yellow #?- Sold
2000 AM General Hummer- Sold
Old July 18th, 2016, 09:41 PM
edfest
Ed Mistler
88 D-110 station wagon 2.5TD
Thanks for posting the links.
I'm having the same issue, and it started when I replaced the diesel solenoid.
At first I thought I didn't install the solenoid correctly, but the problem is intermittent, and if I turn the key slowly, it turns off 3 out of 4 times... And when it doesn't, the battery light comes on. It makes sense that I may be getting low voltage feedback... I'll have to try the wiper switch, before I take the dash off. ��
Old July 26th, 2016, 04:31 PM
FlyersFan76
Darn it.
When I disconnect the wire to my solenoid the engine still runs. I would guess that it is stuck open and I need a new open or clean it. Either way I need to take it out.
Anyone know what the cross reference would be for this at a local shop? Advanced, Pep, etc?
Old July 26th, 2016, 04:45 PM
1of40's Avatar
1of40
1of40
Originally Posted by FlyersFan76 View Post
Darn it.
Call Trevor at Rovah Farm and give him the engine type and year. I'd go genuine.
Old July 28th, 2016, 10:56 AM
FlyersFan76
Thanks. Left message.
Old July 28th, 2016, 12:00 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
delphi solenoid
Hi, I replaced mine a while ago. My aftermarket one had melted the plastic cap.
Trevor does not, or at least didn't at the time, carry the OEM solenoid. I got an OEM Delphi from Oregon Injection for $63 while RN carried the same one for $240 if I remember. After seeing mine, I didn't mind spending ~$40 more for the Delphi versus white box. P/N 7185-900w.
Rebuilt injection pump, injectors or turbo for your Perkins engine.
Just noticed your 110 is a tdi, may be a different solenoid.......
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old July 28th, 2016, 02:17 PM
http://oregonfuelinjection.com/index.php?pid=36#REPAIR_ITEMS,_SUPPLY_PUMPS_&_SOLE NOIDS
great tip!
Old July 28th, 2016, 04:16 PM
GuamBomb's Avatar
GuamBomb
1991 Defender 90
My 200tdi does this also periodically. I find that if I just goose the gas a little it cuts off.
engine
HELP! Key won't turn past 1st position svxaddict Defender Technical Discussions 8 June 25th, 2014 02:44 PM
Turn-Key re-built engines. globallandrovers The Vendors Loft 22 June 9th, 2014 07:05 AM
Help! Cant get the key to turn over hotroddef90 Defender Technical Discussions 10 October 27th, 2012 04:51 PM
Ignition key won't turn! cgalpin Defender Technical Discussions 11 March 27th, 2010 06:42 PM
Turn the key and . . . CLICK! Bozman Defender Technical Discussions 15 January 25th, 2007 02:57 PM
