Turn indicators - Defender Source
Old August 31st, 2007, 01:10 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Turn indicators
I noticed that when I apply my brakes while the blinker is on that the blinkers slow way down and the indicator light on the dash goes dim. Anyone else experienced this or should I get out the small furry creature to sacrifice to Lord Lucas?
Old August 31st, 2007, 01:33 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
mine was doing the same thing when the weather was dry, when wet they worked fine. problem was a loose earth behind the speaker in the rear drivers side. there is a group of 3-4
3rd low and BOOT IT
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Euro style front turn indicators boshea Defender Technical Discussions 12 September 22nd, 2005 07:56 AM
Turn signal--problem solved Davis Defender Technical Discussions 0 July 18th, 2004 08:13 PM
» Defender Registry
Ole Blue
dogbite
130
kellymoe
Add your Defender
