Turn Indicator & Hazard Lights Not Working - Defender Source
Old August 1st, 2016, 01:22 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Hey folks, so suddenly my turn signals stopped working, no blinking, no dash light, etc. Hazards are dead too. All fuses are fine including both the 8A hazard fuse and the 10A breaklights/fuel gauge/turn signals fuses. (This is my v8 fuse map for reference). This is for an 83 110 v8.
So I'm concluding this is either the turn signal switch OR my hazard switch. I think it's LIKELY it's the hazard switch based on my searching. I'm going to try flushing the switch with contact cleaner today. I have to do a long drive this weekend and then will be on MV for a week, so getting a new one is a bit of a rush job. Hand signals are not effective when no one else knows what they mean!
So I've got a few questions:
1. What is the best way to test which is dead?
2. Is there any way to use a non-LR switch attached to the multi-connector in the meantime? This is what mine looks like:
3. Is there anything else I should be checking out/am I away off or does this seem reasonable?
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old August 1st, 2016, 01:38 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
replace hazard switch - all your problem circuits route through the hazard, and they are notorious weak spots
Old August 1st, 2016, 01:41 PM
Naplm00
Matthew
I'll.echo this. Sometimes when my truck sits for a week or so the signals won't blink, just stay solid. Flasher was replaced a while back but, one little flip of the hazard switch seems to fix it everytime.
Old August 1st, 2016, 01:42 PM
Tarheeld
Bill
1985 110
What is the next step if replacing the hazard switch does not fix the problem?
Old August 1st, 2016, 01:43 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Cool, flipped the switch a bunch, so it's more than just a finnicky connection. So question is, if cleaning up the connectors doesn't hurt, do i have a stopgap method of making this connection work for 4 days from now?
Old August 1st, 2016, 02:57 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
I finally found this link which is what i was looking for. The Pin diagram here will help test for power:
Hazard Switch & Indicators - fault diagnosis - Defender Forum - LR4x4 - The Land Rover Forum
Old August 1st, 2016, 04:23 PM
GuamBomb's Avatar
GuamBomb
1991 Defender 90
That link that you reference above is what helped me diagnose my turn signal issue. You can also apply the same logic in that diagram to the indicator stalk. I'm betting that your issue is with the hazard switch so follow the instructions in the link for trouble shooting it first. If that does not find the problem, then remove the plastic covering around the steering column and test if the turn signal stalk/switch is good by jumping the wires at the connection. In my case, i had a bad indicator stalk/switch (they break easily).
Old August 2nd, 2016, 12:37 AM
Tarheeld
Bill
1985 110
My hazard switch works with no problems, lighting/flashing all blinkers. However, my indicator stalk doesn't.
I jumped the Permanent Supply to the Flasher supply, and voila the indicator stalk works as promised.
I can't seem to isolate the problem. Id appreciate your help.
Old August 2nd, 2016, 02:10 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
So I think I've confirmed that it's the hazard switch that's shot. If I run a straight wire from the power supply to each respective spot, the stalk switch activates the proper side markers (at constant on, not blinking). I took apart the switch, cleaned it all out, even broke it down to ifs components, cleaned, and reassembled. Do these parts look like they're in proper shape? So it seems I need a new switch. Anyone know where to get something that would work stat? Hitting the road Friday and could really use turn signals!
Forgot to add RB says end of next week. Fingers crossed for LRdirect or my DMV area homies.
Old August 2nd, 2016, 08:09 AM
Naplm00
Matthew
Top right contact is super worn. Trevor @ rovahfarm might have one. Or in a pinch refill the divots with solder and reshape them with a small file.
Clean everything with rubbing alcohol
Old August 2nd, 2016, 09:30 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Originally Posted by Naplm00 View Post
Top right contact is super worn. Trevor @ rovahfarm might have one. Or in a pinch refill the divots with solder and reshape them with a small file. Clean everything with rubbing alcohol
dagger, he's got em but he's on vacation.
Old August 2nd, 2016, 09:48 AM
MyLeftyLandies
Gary Patterson
1992 LHD Defender Ex RAF 90
I dont know whether yours is an ex military truck with the central rotary light switch but if it is, give that a wiggle between off and position 1. I replaced the hazard light switch many times before realising that wiggling this thing brought all the indicators/brake/horn/hazards etc back to life. If yours is not a military one...as you were....
Old August 2nd, 2016, 10:53 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
sadly no
Old August 2nd, 2016, 12:14 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Dan,
email me your shipping address - we've got them in stock.
brian@defendersnw.com
Old August 2nd, 2016, 01:03 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Dan,
And Brian and DNW save the day!
Old August 2nd, 2016, 03:43 PM
GuamBomb's Avatar
GuamBomb
1991 Defender 90
@Tarheeld. You need to order a new stalk and replace it. Its a pretty easy job.
Old August 2nd, 2016, 04:03 PM
Tarheeld
Bill
1985 110
Thanks. Doesn't that rule out the stalk as being the issue? Jumping the permanent supply to the flasher supply seems to re-power the stalk and it functions as normal. I may be wrong however...
Old August 2nd, 2016, 04:06 PM
GuamBomb's Avatar
GuamBomb
1991 Defender 90
I assumed you were testing the connection at the stalk. If you are testing it at the hazard switch connection and the stalk works then you are correct the stalk should be good.
Old August 5th, 2016, 01:48 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Ugh, new switch didn't solve the issue. Any chance it's the flasher relay? Could the issue be in the harness side of the connection such that poking wires in there makes connections but the little switch prongs don't make solid connection?
And if I want to try to just swap the relay, is there some off the shelf, autozone type relay I could use or does it have to be an LR specialty part?
Old August 6th, 2016, 09:00 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Conclusion post: it was the flasher relay. I'm thinking that other tutorial's note that when making a test connection across the female connectors the indicators shouldn't blink was wrong.
For anyone looking for this relay in an emergency such as myself, this is the one I found at pepboys and did the trick: https://m.pepboys.com/product/details/9103511/01635
ht, lights
How to bypass Hazard Switch (to keep your turn signals) nathanwind Defender Technical Discussions 8 November 14th, 2016 04:03 AM
Troubleshooting: Turn Signals and Flashers not Working LRColorado Defender Technical Discussions 4 January 25th, 2016 05:41 PM
Turn signal & hazards not working - trailer light on Howski Defender Technical Discussions 14 November 9th, 2013 02:26 AM
top warning/indicator lights not working draaronr Defender Technical Discussions 2 May 22nd, 2008 07:43 PM
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
