Turbocharger rebuild kit? - Defender Source
Old August 21st, 2012, 07:57 PM
Anyone know of a good source for the Garrett t25/28?
Old August 21st, 2012, 11:14 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Bill, I've got a rebuilt disco 200 turbo that I need to get rid of if you are interested. Only a few thousand miles on it before I changed my turbo setup for a LHD conversion.
Old August 21st, 2012, 11:31 PM
Thanks. I just got mine apart to look at it this evening and it's just fine. Gonna put it back together and go with it.
What are you looking to get for the one you have, just for curiosity's sale? Always good to have a spare.
Old August 22nd, 2012, 07:30 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I'd just get it from a local turbo shop. I can't remember the name of the place I dealt with, some place between DC and Balt. They were also a CAV shop. Been way too many years.
You never know when you might need some work done.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 22nd, 2012, 09:02 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I think I paid around $450 to have it rebuilt by turbochhargers.com in Houston. I was thinking $300 would be reasonable. Like I said, put very few miles on it after the rebuild. PM if your interested.
Old August 22nd, 2012, 09:07 AM
Naplm00
Matthew
land rover import has the rebuild kit for cheap on ebay. HE can also get the entirte center section if your rotor is borked.
Old August 22nd, 2012, 10:01 AM
I got mine from ebay
Old August 22nd, 2012, 10:24 AM
Naplm00
Matthew
forgot to mention, make sure to check the condition of the interior cast iron around where the wastegate valve sits.
This is a really common place for the housing to crack from the inside and not be visible from the exterior.
My perfect turbo with no play (read POS turbo that was blowing oil and needed replacement) that i got with my truck had this area cracked.
check this pic to see the are I mean
http://forums.lr4x4.com/uploads/1133...2_38_52558.jpg
Old August 22nd, 2012, 11:37 AM
Mine's good there. Thanks. Gonna just get some new bolts and studs and call 'er done.
Old August 22nd, 2012, 01:01 PM
Bill,
That engine was a strong runner. No smoke, good acceleration.
Old August 22nd, 2012, 01:07 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Just an FYI I've been doing a bunch of business with www.blueridgediesel.com . Their parts guy has a 200TDI and is very willing to help Rover guys.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old August 22nd, 2012, 01:45 PM
Originally Posted by 130Tdi View Post
Bill,
Ya I pulled the valve cover off to see how gunky it was inside and it's clean as a whistle. You can see where someone marked parts with a felt marker pen, so it has been taken care of.
I'm just gonna detail the engine a little and use it as is.
Old August 22nd, 2012, 02:25 PM
That must be Elton Wright.
Elton has a very nice 200tdi 109 SW.
Eric
kit, rebuild
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
LT230 Linkage rebuild kit? bharris Defender Technical Discussions 6 March 29th, 2010 06:59 PM
3.9l rebuild kit JohnsD90 Wanted 7 November 19th, 2009 09:50 AM
Rebuild kit for starter motor ini88 Defender Technical Discussions 1 May 23rd, 2008 04:50 PM
Read door rebuild hinge kit Image needed ini88 Defender Technical Discussions 3 November 7th, 2006 01:12 PM
