Turbo / oil pressure / water temp - Defender Source
Old March 19th, 2015, 02:06 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I just got all of the appropriate vdo gauges and I believe the correct sensors for oil pressure, water temp, boost etc...for a 2.5td where are the appropriate places to tap...for the boost I have heard T the pipe from the turbo or from somewhere on the manifold? Water temp, do I just swap out the current sensor (where is it located) and does the system need to be drained first, and where would I put the oil pressure sensor?
Adam...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old March 19th, 2015, 02:09 PM
Yes
Yes, right by the thermostat housing
No
VDO sells a replacement sender with 2 poles. One for the light and one for the oil pressure gauge. You might need an extension fitting too to solve a clearance issue with the new sender.
Old March 19th, 2015, 02:43 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
This is the sensor I ordered...where would you install it...and I only see one copper what looks like a screw terminal...so how is it wired up...?
ID:	116444   Click image for larger version
Old March 19th, 2015, 03:42 PM
It will power the gauge but not the warning light. Return it and get the double one. It will screw in on the plate between the engine and the filter. If you do a search you can find the thread pitch for the 90 degree adaptor.
ID:	116457   Click image for larger version
Old March 19th, 2015, 04:15 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Dave,
Amazing engine photography! I can never seem to get that kind of ligting or focus!
Old March 19th, 2015, 06:32 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Originally Posted by Greenbull View Post
Dave,
Just open the bonnet or use the flash!
Old March 19th, 2015, 06:42 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Ok...so I guess this sending unit... https://www.egauges.com/ProductDetai...ctCode=360-009
Old March 19th, 2015, 07:27 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Dave...thanks for the assistance...I am glad there are always people to help the NFG's...Adam
water
300tdi turbo pressure line plumbing Blake Defender Technical Discussions 6 March 16th, 2015 12:14 PM
2.5TD 19J Turbo Boost Pressure Numbers? richord Defender Technical Discussions 1 August 25th, 2014 02:19 PM
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
oil pres + water temp gauge??? revtor Defender Technical Discussions 1 July 10th, 2007 09:35 PM
