Turbo oil feed banjo bolt size? - Defender Source
Old July 22nd, 2013, 09:51 AM
My banjo bolt has gone the way of the dodo bird. Extinct, no longer apparent, unfound. I guess the next step is to replace it. Jegs' has about a gazillion banjo bolts....10mm, 7/16ths, 14mm, and I am unsure which one to order. Anyone have this info?
Old July 22nd, 2013, 04:55 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Bill I think it's M12x1.5 (ERR1125) if you measure the hole it should be 10.5mm
regards
Gren
200tdi spill rail Banjo bolt torque tomaco1 Defender Technical Discussions 4 April 19th, 2012 03:29 PM
300 tdi oil cooler fitting thread size Overlander Defender Technical Discussions 8 September 16th, 2011 12:34 PM
help! anyone know bolt size for alternator? paluskat Defender Technical Discussions 5 December 31st, 2010 08:05 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
bolt size for bonnet hinge Campbell Defender Technical Discussions 1 November 7th, 2003 10:41 AM
