Turbo Hose - Defender Source
Old May 20th, 2008, 10:13 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
Turbo Hose
Just wondering if anyone can tell me where the clamp on the lower intercooler hose attaches. Am I missing a bracket or does it just bolt to the inner fender/wheel well?
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old May 20th, 2008, 10:21 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will look at mine tomorrow but I think it is right where your clamp is... The hole is through the wheel well..
Legend in My Own Mind.
Old May 20th, 2008, 10:47 PM
Abrooks's Avatar
Abrooks
Tony Brooks
No clamp at all on mine.
Old May 21st, 2008, 07:08 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mine is right where your pic shows yours and I drilled a hole in the inner wing and bolted it on. Mine has a spacer behind it to keep stuff in line..
Old May 21st, 2008, 09:53 PM
moose's Avatar
moose
Brett
Alright, thanks Randy. An easy fix for a change.
Brett
Ex-Mod 110 Tdi
Old May 22nd, 2008, 11:45 AM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
Clamp
The mounting hole with this originally seems to be one of LR famous rivnut type affairs. A hole is drilled in the part, a nut plate is pressed in, in this case a panel and the idea is you bolt through from the other side.
I'm in the process of doing over a few things on the truck and working in this area right now. Why in tarnation LR bolted into the fender well instead of from the fender well into the engine bay on all their stuff I will never understand. Each mounting fastner for both front fender wells either broke off or stripped by the time they were half way out.
While on the subject of engine plumbing- does anyone know if there is an off the shelf source for steel braided lines for the Oil Cooler system on a 300 Tdi?
300 tdi air filter to turbo hose discotdi Wanted 4 August 16th, 2009 07:18 PM
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
remote turbo? Rod Hayward Defender Technical Discussions 7 January 11th, 2005 04:16 PM
