Tune Up - Defender Source
Old April 28th, 2010, 04:33 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Tune Up
So since the PO didn't drive the truck much, and I managed to pull the boot off of the coil wire, I've decided to do a full tune up. I mostly had questions about brands recommended, i.e. napa oil filter vs genuine vs other, etc.
Plug Wires (currently rists suppression 1515 OEM?)
Oil Filter
Fuel Filter
Air Filter
Also, I want to switch to 0w40 or 10w40 high mileage mobil 1, and my dad who was a classic car collector used to swear by marvel mystery oil in the oil pan for ~1k miles to clean things up, thoughts on adding MMO to current oil, running a bit then changing out for Mobil 1?
Thanks everyone!
Old April 28th, 2010, 04:39 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Just make sure you stay genuine with the cap and rotor. The after market stuff causes too many issues to be worth any savings.
Old April 28th, 2010, 04:46 PM
magnecor [sic?] 7mm wires with a genuine coil wire with the boot over the coil on it.
Genuine oil filter (I sometimes use motorcraft ones as when Land Rover ran out of oil filters they said this was ok to use)
Genuine air filter
Genuine fuel filter
Genuine spark plugs
Genuine cap and rotor.
300 TDI Tune Up Manimal Defender Technical Discussions 30 April 20th, 2011 10:42 PM
Tune Up Advice bbusino Defender Technical Discussions 11 May 30th, 2008 04:47 PM
TUNE UP KIT&ALLOY LUGS WANTED 83 110 mountainviewrover Wanted 4 April 6th, 2008 12:44 PM
tune resistors and cats vesparover Defender Technical Discussions 3 March 13th, 2006 10:34 PM
NAS spec D90 tune resistor help required UKlandyandy Defender Technical Discussions 8 May 7th, 2005 07:05 AM
