tune resistors and cats - Defender Source
Old March 13th, 2006, 07:43 AM
vesparover's Avatar
vesparover
brian bertolini
I was just at the rpi site and did some reading on tune resistors. If I'm not running cats, would having a tune resistor for cats cause any problems? Wouldn't it just run rich? Any body out there who has removed their cats changed out this part?
Brian Bertolini
Old March 13th, 2006, 12:03 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Not too long ago somebody ran a series of tests on the various fuel maps that the tune resistors gets you. The fuel map for use with the cats does run very rich during acceleration , though they all run about the same when at a steady speed and the engine is warmed up. But simply removing the cats wouldn't cause the engine to run any different, as all measurements are taken before the cats anyways.
Though the exhaust will be extremely polluting in comparison to running with cats, I found this out due to the previous owner gutting the cats on my truck and passing inspection was just impossible without new ones.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 13th, 2006, 10:29 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
-Hans
So I'm also guessing that you didn't notice any performance change once you added the cats?
Old March 13th, 2006, 10:34 PM
Hans's Avatar
Hans
Hans Haase
Nope, no difference other than passing emissions testing finally and no more hiding from the cops.
-Hans
My oil line fix
Issue with Exhaust - It STINKS Literally hutch Defender Technical Discussions 43 January 23rd, 2007 08:50 AM
"tune resistors" boxerhips Defender Technical Discussions 3 January 17th, 2006 07:10 AM
GEMS or Bosch boxerhips Defender Technical Discussions 34 January 5th, 2006 05:25 PM
