Tuffy spacing - Defender Source
Old March 19th, 2008, 01:59 PM
Tuffy spacing
Can someone tell me how much vertical room is under the tuffy console? looking to put a marine amp under there and want to know if it will fit, or if I might need to space it up a bit.
Old March 19th, 2008, 08:02 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
Mark,
If you are talking about the center console, basically there isn't any room.
I don't know about the rear tuffy's.
Kris
Old March 19th, 2008, 08:10 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
My tuffy is sitting on 1" spacers--now that I have raised my seat, I might raise it a little more--nice idea about the amp--I might put one there. Just make spacers to adjust if it is not too high ergonomically. For spacers, I used square tubing run horizontally perpendicular to the tuffy.
Old March 19th, 2008, 08:40 PM
Thanks. I'll post pics of whatever I end up doing. I'm building a carpc with touchscreen, which I'm going to document.
Old January 24th, 2009, 03:54 PM
JRW's Avatar
JRW
94 D90 ST #1247
Mark ~ Did you ever mount the amp under the tuffy box? I think I am about to do the same thing and wanted to see how it turned out.
Old January 24th, 2009, 07:39 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
ECR has mounted power inverters there. Take a look at their website, I forget which truck has it, but they installed it in a 110 I believe.
Old January 26th, 2009, 09:18 PM
Davis M's Avatar
Davis M
HDM
'93 Defender 110
I'm using 1 1/2" spacer on the wide Tuffy box. Much higher than that and I'd be hitting the box with my arm when shifting; much lower and the arm pad would be useless. Using channel stock (i.e. U-shaped aluminum or steel) instead of square will give you additional room for wiring and such.
Old January 27th, 2009, 10:32 AM
JRW's Avatar
JRW
94 D90 ST #1247
Thanks all. Upon further reflection, I think I am just going to mount the amp inside the tuffy box...
Old January 27th, 2009, 12:58 PM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
Heat?
If you do that, I'd seriously consider fabricating up a fan and shroud - in Texas, the heat will melt that amp in a hurry.
Old January 27th, 2009, 05:44 PM
Montgo1715
D Montgomery
1994 AA
John, Earmark in Dallas mounts them in the compartment under the passenger seat, which is what I plan to do (or have them do it).
Has anyone run into issues with that?
Now that is a big trunk. It holds a tuba, a suitcase, a dead dog, and a garment bag almost perfectly.
Old January 27th, 2009, 05:52 PM
JRW's Avatar
JRW
94 D90 ST #1247
That's where I had mine in the past, but I was trying to free up more room for a future air compressor and other goodies.
Also, what is the temperature and airflow difference between the passenger seat box and a tuffy console? Both have about the same volume and neither have active airflow?
Old January 28th, 2009, 09:24 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I built a slide-in bracket to mount my amp underneath the driver's seat, next to the battery, on the interior (passenger) side of that box. It's been in there for two years with no issues so far.
Old January 28th, 2009, 10:25 PM
JRW's Avatar
JRW
94 D90 ST #1247
Chris - PM sent for pictures...
Old January 28th, 2009, 11:08 PM
chris snell
Chris Snell
87 Ex-MOD 110
Here you go.
There are two pieces of aluminum bar attached to the amp with spacers and two more attached to the walls of the battery box. Each forms an "L" shape that interlocks. It's not the same as bolting it down but it doesn't seem to rattle and it's easy to slide out when you want to work on it.
Damn, my seat rails are rusty. Time to refinish or replace.
ID:	17553   Click image for larger version
Old January 29th, 2009, 10:01 AM
JRW's Avatar
JRW
94 D90 ST #1247
Thanks Chris!
ac
Rear Tuffy Box for a 110 pcarey Defender Technical Discussions 12 March 4th, 2006 11:27 PM
Cheapest place to buy Tuffy console, Mantec snorkel Chris Cox Defender Technical Discussions 7 March 14th, 2005 09:21 PM
Tuffy Storage Box RyanS For Sale - Parts 11 February 17th, 2005 09:43 AM
Which Tuffy boxes do you use? DiscoDino Defender Technical Discussions 4 January 21st, 2005 06:04 PM
Tuffy Storage Boxes ronward Wanted 9 September 29th, 2004 01:33 PM
