Tuffy install ROW 110 - Defender Source
Old January 28th, 2013, 08:16 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Before I start drilling holes, does anyone have any pictures, lessons learned or instructions on installing a TUFFY in a ROW vehicle? It is simple enough -- but thought there might be a recommended solution out there.
------ Follow up post added January 28th, 2013 08:17 PM ------
By the way... the 'Charcoal Grey' is not really charcoal. Its really light grey, but I'm too cheap to pay for the shipping to send it back to get black. Just letting any potential tuffy buyers out there know
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old January 30th, 2013, 12:19 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
In my ROW 110 CSW there is a removable panel under the middle seat. I made a template then drilled through that. Put mounting bolts through it, heads on the underside, locked them down with nuts. Now have a panel w/ 4 bolts sticking up. Used 1" sound down (dense foam stuff) cut out some space for the nuts and drilled through for bolts. (A sandwich of foam between panel and tuffy.) Used acorn nuts on the inside of the console I may add a length of 1/2" angle iron to the length of the panel held down by the same bolts just to stiffen it up a bit. The panel flexes up a tad due to compressing the foam.
Old January 30th, 2013, 10:58 PM
coffee's Avatar
coffee
John Oates
1993 NAS Defender 110 #367/500
The 110 kit comes with three bolts, all of which require 3 new holes to fit the Tuffy holes. I used the front hole, then drilled new holes in the tufty floor to match the existing two back holes. You can do this by anchoring the Tuffy in place, then drilling pilot holes from underneath the truck through the floor of the Tuffy box. That way you are only drilling one new hole. I just read the previous post on the padding - I wish I'd have added some type of pad below before adding spacers and installing.
Old April 20th, 2013, 11:16 PM
silverlight's Avatar
silverlight
Geoff
1993 Defender 110 NAS
Awesome idea! Thank you for that. I just installed a Tuffy box this evening and did exactly this. I'm now using the 4 OEM bolts in the OEM position and drilled 3 holes in the tuffy. I didn't have any of the insulation, but I added dynamat to the bottom (underneath) of the box and black removable metal plate already had it on both sides. Very solid install.
My only complaint... drink holder did not fit in the front, so had to mount it to the rear. Better than nothing though!
Old April 21st, 2013, 09:05 AM
coffee's Avatar
coffee
John Oates
you might try spacers or raising the cupholder a little - I was able to fit a cup holder in front and in back with no clearance issues. good luck.
ROW 110 200tdi implant 1of40 For Sale - Vehicles 12 October 17th, 2012 02:35 PM
trade NAS D90 for ROW 110 5 door spartan For Sale - Vehicles 0 September 22nd, 2012 12:14 PM
Custom middle seat install on 110 ontheway Defender Technical Discussions 11 August 21st, 2012 10:24 PM
110 row 1of40 For Sale - Vehicles 25 September 29th, 2010 01:01 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
