Tuffy Center console mounting - pics needed - Defender Source
Old August 22nd, 2013, 03:31 PM
Ok... Was looking at how my tuffy was mounted last night to figure out how to stop the blast furnace that is leaking in via the gap in the cover plate and the hardura.
Basically the console is mounted directly to the transmission cover - this is definitely not correct since it does not use the feet looking part that is suppose to come with console.
does anyone have a couple of pictures of how it is suppose to mount especially where it bolts to.
I need to redo the whole thing. why lock it if you can unscrew 2 screws and pull the whole thing out in about 30 seconds.
95' D90 - daily driver..
Old August 22nd, 2013, 04:52 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
tuffy box
Well this is how the Tuffy box on my D90 was attached by the previous owner. Rear held in place by attachment tabs, holes are threaded. Bolted from inside. Now we are left with the front holes to secure. No holes on the transmission cover line up, so you need to drill at least two holes. If you have a helper they can hold a lock washer from underneath the car while you secure the bolt from above. Or, drill twin holes and use zipties. Ultimately, a professional car thief can steal anything, so don't put anything too valuable inside the Tuffybox.
Old August 22nd, 2013, 07:51 PM
Pictures please
Old August 22nd, 2013, 10:20 PM
CaptMidnite
Daniel Choi
pictures attached
Attached are the pictures of my Tuffybox mounts. Note my project is still in progress, so the front mounts are a proposed solution- I haven't done them yet.
The rear mounts are basically "L" shaped metal tabs bolted to the body seam where the seat box meets the rear bed. The tabs are then threaded so they can accept a bolt.
ID:	78074   Click image for larger version
Old August 26th, 2013, 10:29 PM
coffee's Avatar
coffee
John Oates
1993 NAS Defender 110 #367/500
If you dont want to drill new holes in your floor, just put the box in place, then drill up through the holes from under the truck - making new holes in the tuffy box. worked well for me.
console, mount
Tuffy Series II Security Console pacificwildfire For Sale - Parts 8 March 3rd, 2013 12:02 PM
Stock 97 auto console mounting location pics? Broncoduecer Defender Technical Discussions 5 June 13th, 2011 09:25 PM
Defender Seats and Center Console ron For Sale - Parts 3 October 23rd, 2010 01:30 AM
Ashcroft center console install...pic's mongosd2 Defender Technical Discussions 0 September 6th, 2010 06:25 PM
Tuffy Center Console TravelerBT Wanted 6 January 18th, 2009 11:33 AM
