Tuffy box removal/ Rear load mat install - Defender Source
Old March 6th, 2008, 05:42 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I searched and got a ton of info on the center console and how to modify it but I have a box in the back.
The PO installed it over the wheel well and I need to remove it to install the load space mat. BUT I have to do it by myself and wanted to know if ya'll had any ideas to get the nuts out. The PO mounted it with the nuts in the box and I can't hold the bolt head and undo the nut. I also need to reinstall it after I put the mat under it.
I'd like to remove the seat mounts on the floor and the sides of the wheel wells for the bench seat so I can put the mat in and then reinstall these too. It seems to be the same deal as the box. I don't want to cut the mat for these if I can avoid it.
Alex
Old March 6th, 2008, 06:21 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Visegrips, my best friend.
Semper Fi!
Old March 6th, 2008, 06:55 PM
aosias's Avatar
aosias
Alexandra
1995 D90
vice grips on the nut or the bolt? DIY things are new to me.
Old March 6th, 2008, 07:03 PM
Abrooks's Avatar
Abrooks
Tony Brooks
The last mat I installed (ST so it went over the wheel wells) ripped at the seems in a month. What advice can people give on getting these lined with line-x or one of the competitors? Greg, you had some plusses and minuses from the last time you had it done, didn't you?
Old March 6th, 2008, 11:39 PM
TND90's Avatar
TND90
Keith Allen
94 d90 ST
Tony,
I had the same problem with my soft top rear mat. My solution was to line-x the rear tub over the exact same area the original mat covered. I actually used Hurculiner from Autozone for a do it yourself approach. I pulled all the bolts and brackets out of the tub so they would not be "lined" in. I like to keep the 90 somewhat factory. Keeping this in mind, we decided to cut the oval Land Rover logo out of the used mat, glue it to the tub in the same place it would normally rest, and line-x over it. Turned out really sweet. Also keeps the factory look with a much better result. The project was fairly inexpensive and took about 3 hours to complete. Most of that was prep time removing bolts and taping everything off.
I will try to take some pics and post over the next few days.
Keith
"There is no normal life Wyatt, there's just life."
Doc Holliday
Old March 7th, 2008, 06:16 AM
Wolf Fabrication
Sterling Archer
'08 D3
Sorry, vicegrips on the nut inside the box. As you loosen from below the vicegrips will turn and hit the edge of the box and hold it for you. You can also use a box wrench, but they usually pop off.
Semper Fi!
Rear Tuffy Box for a 110 pcarey Defender Technical Discussions 12 March 4th, 2006 11:27 PM
Tuffy Rear Box pcarey Defender Technical Discussions 9 February 21st, 2006 03:08 PM
Tuffy Box GeoParth Defender Technical Discussions 15 July 5th, 2005 10:13 AM
looking for SW rear load space mat NASD90 Wanted 1 December 13th, 2004 04:51 PM
