Tuffy Box lock question - Defender Source
Old July 7th, 2008, 03:24 PM
snurp
Keith Kuboske
94 D90 ST Arles Blue
Not sure what happened to the lock, but the female portion that accepts the key is halfway between the two keyed opening sights (the open and locked posistion). The key will not go in obviously and cannot rotate back to either posistion. Not sure, but think someone tried to get in the box as I had the battery disconnected as I had left it outside and was gone for a week. (little did they know the cutoff is under the seat).
Does anyone know how to fix this or is a locksmith the best alternative? The box is locked tight and cannot get into it.
Keith
94 D90 ST White
02 Disco II
Old July 7th, 2008, 03:36 PM
tuffy may be able to help too, I bought a used box on ebay and needed some lock parts, they were real helpful
Keith
Old July 7th, 2008, 03:57 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Maybe try a large prybar or screwdriver to move it back to the locked position, then try the key again?
Semper Fi!
Old July 8th, 2008, 03:08 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I have a laundromat with similar locks on all my machines. The locks seem to magically turn a little all the time and the nub on the key will prevent you putting the key in the hole. The previous owner ground the nub off the edge of the key so it fits down into the female portion of the lock and then you can turn the lock. The keyed part is on the round part of the key. That nub is not necessary.
Rear Tuffy Box for a 110 pcarey Defender Technical Discussions 12 March 4th, 2006 11:27 PM
Tuffy Box GeoParth Defender Technical Discussions 15 July 5th, 2005 10:13 AM
Tuffy Storage Box RyanS For Sale - Parts 11 February 17th, 2005 09:43 AM
Tuffy Box Zimbo76 Defender Technical Discussions 6 May 12th, 2004 04:26 PM
Tuffy Push Button Keyed Lock for sale mgrgpg For Sale - Parts 1 March 9th, 2004 01:48 PM
