Tucklite ? - Defender Source
Old September 18th, 2016, 11:00 PM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Tucklite ?
I just installed a pair of headlights in my 90. Pretty simple plug and play installation. When I turn the low beams on, I get very little light. The high beams are bright as hell. Thoughts?
Old September 18th, 2016, 11:17 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I'd get a relay and wire them directly to the battery; arb has a kit
Old September 19th, 2016, 07:18 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
They should be drawing less power then the original lights. However it does sound like there is an issue a relay would solve.
Old September 19th, 2016, 08:13 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Yes, ground or otherwise this would be the simplest solution
Old September 19th, 2016, 09:59 AM
AdamSanta85
91' D90 200TDI
Why don't you try adding a temporary additional ground to one of those lights to see if the low beams improve. If that works you know where to start.
Old September 19th, 2016, 10:11 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Mark-the lights should be pretty bright at night on low beam, but the brightness during the day (if that is what you are looking at) does seem dim. I've installed two sets, no issues with plug in play. I agree ground may be poor, I see no reason to run a harness, as they underlining issue should be addressed.
1991 Range Rover Classic
1994 Defender 90
2006 LR3 SE
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
1996 Discovery I (sold)
2006 LR3 SE (sold)
Old September 19th, 2016, 10:34 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I think in general the relay does have the added bonus of saving the switch, they aren't cheap either IIRC
Old September 19th, 2016, 04:01 PM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
So, if I'm standing up and look at the low beam lights, they are very dim. If I get down on my knees and look, they are far brighter. Will try re aiming them up. Just seems strange because I figured I would see the light on the ground if they were aimed way down. More to follow.
Old September 19th, 2016, 04:34 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
In daylight, yes. Post a pic looking from driver seat with low beams on at night.
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old September 19th, 2016, 07:33 PM
Set them for position facing a wall. There is a height / distance for the beam pattern that balances light vs dazzling people.
» Defender Registry
Bobby
curry
No Frills
CDN d90
Add your Defender
