Tubeless Valve Stems in NAS 110 Steel Wheels - Defender Source
Old March 17th, 2009, 02:17 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
When I purchased my 110 it has pull through valve stems in the steelies and tubeless BFG's mounted. I scrapped the stems when I had the wheels refinished, but the standard valve stems that we use at the dealer seem a little loose in the tube wheel valve hole. I mounted four of the tires last night and they hold air fine, but I am concerned about the valves not being tight enough when the tires are aired down for off-road use. I would like to replace the valve stems with a bolt in style, but I can't seem to find them in the proper diameter. What has everyone else done that has switched to tubeless on the NAS 110 steelies?
Thank you.
Old March 17th, 2009, 03:43 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Generally the clamp style come with two grommet sizes included, for .453" and .625" holes. I got some really short ones at NAPA that fit my Wolf wheels.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 17th, 2009, 04:02 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Ok, I'll try NAPA then. Thanks Tom!
Old March 17th, 2009, 06:36 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
One thing to remember with some of the steel rims is that they don't have a bead retention lip to help keep the tire on the rim in case of low tire pressure - just a safety heads up.
Old March 18th, 2009, 10:58 AM
Why are you not running tubes? Tubes are good.
110, nas, nas 110, steel wheels, wheel, wheels
WTB: NAS 110 steel wheels!!!! Blakesrover Wanted 1 October 10th, 2009 04:14 PM
Genuine NAS 110 Steel Wheels FS ANR1534PM SafariHP For Sale - Parts 5 February 27th, 2008 11:09 AM
NAS 110 Steel Wheels / Mantec Intakes FS SafariHP For Sale - Parts 9 January 27th, 2007 02:01 PM
110 steel wheels and tires artm For Sale - Parts 3 January 21st, 2005 09:06 PM
110 Steel Wheels in Denver Area? dnewman9 Defender Technical Discussions 0 January 20th, 2004 05:03 PM
