Tubed and Tubeless rims - Page 2 - Defender Source
Old January 17th, 2008, 09:54 AM
I have the original NAS 110 tubed steel wheels, and have been running tubeless BFG mud's on them for over 6 months. no issues whatsoever, and no abnormal air loss.
I was able to mount the BFG's myself with an Outback tyreplier set and my portable compressor. They easily inflated once mounted.
I prefer having my BFG's on tubeless rims, as they make field changins and repair of rims much easier, and I can carry a tube as an emergency if all else fails to get me back. With a full spare, an ARB radial tire repair kit, a compressor and tyrepliers, I have no concerns on being stranded due to tire issues.
Old May 8th, 2009, 09:00 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Hi Mark,
I have been reading about tubeless tires on tubed wolf rims and on this last post you say this...
"I have the original NAS 110 tubed steel wheels, and have been running tubeless BFG mud's on them for over 6 months. no issues whatsoever, and no abnormal air loss.
I prefer having my BFG's on tubeless rims, as they make field changins and repair of rims much easier, and I can carry a tube as an emergency if all else fails to get me back. With a full spare, an ARB radial tire repair kit, a compressor and tyrepliers, I have no concerns on being stranded due to tire issues."
Did you mean to say "tubeless" rims in the last paragraph? It confused me since the first line says you run tubed rims...your post was informative and I wanted to make sure I understood what you meant...
thanks!
George
Old May 9th, 2009, 02:41 PM
thanks!
George
Good catch! yes, the last paragraph should have read tubed, not tubeless. my factory rims require tubes, and I prefer it that way. unless running very low pressure off road (which I haven't done yet), haven't had any problems with them. tubeless tires are going to be easier to get off a tubed rim then a tubeless rim.
Old March 28th, 2010, 10:44 AM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
Standard tire pressure for normal road conditions
What should the fwd and rear tire pressures be for tubeless 235/85R15 tires on stock rims for a NAS 110 truck in normal road driving conditions?
Do, or do not, there is no try!
Old March 28th, 2010, 12:45 PM
I'm not sure what it's supposed to be, but I run 45 front and rear and have very little wear on my BFG M/T's.
Old March 28th, 2010, 04:23 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
It's supposed to be lower at the front and higher at the back.
27 & 42 psi Front & rear.
Having said that I run 40 psi front and 50 psi rear on my 200tdi. With no power steering (it was made that way) and 27psi in the front tyres it takes a mighty effort to change direction when parking
Mike Hammond
rims
Wolf vs D110 Steel wheels jaygoss Defender Technical Discussions 20 March 6th, 2010 03:27 PM
35 x 12.5" tires on D110 wheels - de-beading cdb Defender Technical Discussions 15 July 16th, 2009 09:41 AM
Steel Wheels bjf Wanted 13 October 28th, 2007 07:37 PM
tubless tires on tubed wheels asurover Defender Technical Discussions 2 February 3rd, 2005 01:30 PM
Steel Rims thug1313 Misc. Chit-Chat 6 September 26th, 2004 03:01 PM
