tub width on a '94 D90 is tapered "natural"? - Defender Source
Old August 18th, 2004, 04:21 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
I need to build - well need is a bit strong but that is what I told my wife and I am sticking to it - a cover for my tub on the D-90. While taking the measurements, I found that the tub tail width is 1 inch wider than the width just behind the seats. Is this normal? I would have thought the tub to be a true rectangle. As it is, a 4 ft length of wood tapered from 5ft to 5ft 1" is needed.
As an FYI, my plan is to leave the full safety cage in place, cover the tub with t&g wood flooring, and varnish or paint the hell out of it for sealing. A 1x 1/4 inch frame sitting on rubber will address the endges. Then the fun part will be making speaker boxes for the two rear marine speakers and if my wood talents prove up to it, boat style drop storage bins down the sides (lockable of course). The front seats are to be covered by an adapted 1995 D-90 soft top (so far the most difficult piece to trim into place).
Old August 18th, 2004, 04:27 PM
5' 3/8" behind the seats, and 5' 1" at the tail. Why, well every D-90 is special
Old August 18th, 2004, 04:33 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
You thought something on your truck would have the same measurements as different ends?:smileThe sides behind the front seats are pretty flimsy with no bulkhead. There is alot of play in those sides when putting one together. Accounts for it not being square.
Old August 18th, 2004, 07:07 PM
paulb's Avatar
paulb
Paul / Boultbee
Why, I did not assume it would be square (silly me).
My surprice is that it is ONLY 1" off.
As Mike puts it... they are all special.
90, d90
rollcage,ARB's, 4.10's GBR, badger, D90 tub Shane@EVS For Sale - Parts 20 March 20th, 2006 06:41 PM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
Stock 94 D90 Parts For Sale Joe B For Sale - Parts 1 January 14th, 2004 01:52 PM
Is it a 94 or 95 D90? PT94D90 Misc. Chit-Chat 5 November 12th, 2003 01:17 PM
