Tub stiffeners. - Defender Source
Old May 8th, 2009, 10:58 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Tub stiffeners.
So, in the category of "I should have taken a photo beforehand" (which I'm sure there will be more of sadly), I got a pile of stuff back from galvanizing including the tub lateral stiffeners. What I don't recall is if the small black high-density foam squares were between the tub floor and the stiffener or between the stiffener and the chassis.
There seems to be a gap between the stiffener and the tub floor, but this could just be sag from sitting so long without them riveted in place. I just want to be sure before I put things back together incorrectly.
Thanks.
Old May 8th, 2009, 10:59 AM
Stiffener and chassis.
Ron
Old May 8th, 2009, 11:04 AM
ajh
Andrew J. Hutton
OK, that was my gut feeling, so as long as the stiffeners look un-warped then just flex things to fit? I guess it's time to track down some 3/16th closed end pop-rivets. I've been contemplating using round-head solid rivets everywhere possible but I'm now thinking that might be more work than needed in the non-visual locations.
Thanks.
Old May 8th, 2009, 11:10 AM
Yes, they probably warped in galvanizing. Once it is all bolted/riveted together it should be fine. The correct rivits are flathead hammer rivets IIRC (I know they are on a series, truck, I would have to look again at a D90/D110).
Ron
Old May 8th, 2009, 11:25 AM
ajh
Andrew J. Hutton
Yeah, that would be the correct ones, but I'm planning on putting in a drawer system anyway, so if closed end pop rivets are strong enough I'm tempted. Of course I could also just bolt it through but there will be a time without the drawer in and that wouldn't be as nice.
rollcage,ARB's, 4.10's GBR, badger, D90 tub Shane@EVS For Sale - Parts 20 March 20th, 2006 06:41 PM
SW driver/passengerside doors wanted as well as centor console tub jchan88 Wanted 4 August 7th, 2005 09:04 PM
Galvanised tub capping jabber Defender Technical Discussions 9 March 3rd, 2005 09:35 PM
body capping on rear tub WhiteD90 Defender Technical Discussions 5 October 6th, 2004 06:10 PM
tub width on a '94 D90 is tapered "natural"? paulb Defender Technical Discussions 3 August 18th, 2004 07:07 PM
