Tub Refurb - Defender Source
Old May 25th, 2015, 10:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Tub Refurb
Need to do a bunch of repairs on the 110 rear tub.
Looking to patch some areas. Main question - should I use an adhesive or sealant between the original tub aluminum and the patch piece? I will
be using rivets to attach.
Pic of one of the sides that needs some help.
Old May 25th, 2015, 10:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Same side - lower corroded area.
Old May 25th, 2015, 10:15 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Why not just cut out the bad sections and weld in good metal?
Old May 25th, 2015, 10:23 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
I would cut out the aluminum corrosion rot and patch with similar thickness aluminum sheet panels. Seam sealer and rivets should do the trick and be a strong repair. Paint and voila you are good to go. Good luck.
Old May 25th, 2015, 10:46 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Haven't weld Aluminum yet. I might just do that to other pieces that I can put on my welding table.
------ Follow up post added May 25th, 2015 10:47 PM ------
Thanks RoverDoc - I was certainly going to cut back to decent material. Any seam sealer should work?
Old May 25th, 2015, 10:51 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Don, check out my build tread (b777onr) same issues I made plates, glued 3M and rivets
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 26th, 2015, 07:13 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Ah - great! Looks just like my issue. Very nice work!! Will use your pics as a guide. Any idea what 3M glue you used?
------ Follow up post added May 26th, 2015 07:13 AM ------
Thanks for the link Jeff!
Old May 26th, 2015, 02:11 PM
if you have a mig or tig, i would vote to weld a clean repair.
you don't need a spoolgun, just straight argon.
Old May 26th, 2015, 02:34 PM
roverman2010
1985 LR 90 200Tdi
Sorly it wasn't 3m but Eastwood structural panel adhesive, I used just less than one tube.
I would have tig ed the panels in, but I still can only do bench work nicely..
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old May 26th, 2015, 04:22 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
if you have a mig or tig, i would vote to weld a clean repair. you don't need a spoolgun, just straight argon.
I have a TIG machine - I might just give it a try
Old May 26th, 2015, 04:45 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
these might come in handy. 8 Piece Butt Welding Clamps -Jeff
Yup - actually looked at them last time I was in Harbor Freight. Will swing by and grab a set next time I am in that area.
Old May 26th, 2015, 05:05 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
Can your tig machine do AC?
Old May 26th, 2015, 07:16 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
It can
Old May 26th, 2015, 07:37 PM
DefenderMd's Avatar
DefenderMd
Ben
Well wTf.. you're a professional.. weld it!
My welding shop guy doesn't even have AC tig. "no market". I mean even at a hobby duty cycle that's better than a $1000 machine. I'd be using that thing for everything.
Old May 26th, 2015, 08:47 PM
AC is good. However, you don't need AC to TIG aluminum. The phrase "You must have AC to weld aluminum" is all over the internet, but it's a straight up lie. For example, virtually the entire APS at Argonne National Labs has its entire aluminum beamline welded with DC TIG. And that isn't off-road equipment welding - it's hard vacuum, high-radiation welding for a coherent X-ray source.
Just use DCEP, a big fat tungsten to sink the heat, and use a higher than normal gas flow (or 100% helium shielding gas.)
Old May 26th, 2015, 08:56 PM
DefenderMd's Avatar
DefenderMd
Ben
I'm no expert at welding by any stretch. I don't even own a tig welder. I wire feed and stick, un shielded, outdoors. "farm style".
But its all over miller's website too. You may be right.. but it isn't what seems to be taught. I didn't get my info from the internet. I got it from welding class. Now... among specialist groups, it is common to continue spreading false information based on ... where is the new info coming from? Once they're in the field and do it the way that works for them, they can be very skeptical of new information.
I don't understand completely what AC does for the weld. When I read about welding aluminum, its all about the oxidation. Sounds like from your description AC somehow lowers the temp (ergo big fat tungsten to spread the load?)
I've got an appointment with my welder guy to get the front crossmember and surrounding area, removed/replaced/beefed up for winching and maybe plowing. I'll see if he can put a fine point on this. He's fairly young, but has had experience in a broad range of welding careers.
and unfortunately helium is probably a resource we won't have in a few years.
At any rate. OP can weld his bed and it will be stronger and probably prettier than rivets.
also... how does a bed get THAT corroded that quickly? I would think the frame would be gone by the time the electrolysis got to it.
Old May 26th, 2015, 09:54 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
AC is good. However, you don't need AC to TIG aluminum. The phrase "You must have AC to weld aluminum" is all over the internet, but it's a straight up lie. For example, virtually the entire APS at Argonne National Labs has its entire aluminum beamline welded with DC TIG. And that isn't off-road equipment welding - it's hard vacuum, high-radiation welding for a coherent X-ray source. Just use DCEP, a big fat tungsten to sink the heat, and use a higher than normal gas flow (or 100% helium shielding gas.)
Interesting - never knew that about Aluminum welding in DC but my knowledge and skill are still pretty remedial. Will have to talk to my welding buddy and see what he has heard about that method. He welds with some pretty cool metals at work - inconel and titanium. I don't have any fat tungsten so will do my AL learning in AC but neat to hear that process.
------ Follow up post added May 26th, 2015 10:03 PM ------
At any rate. OP can weld his bed and it will be stronger and probably prettier than rivets. also... how does a bed get THAT corroded that quickly? I would think the frame would be gone by the time the electrolysis got to it.
My welding buddy said rivets are actually pretty good way to join things. I am going to try and fix my fender first and if that goes ok I will try some welding on the tub.
Don't even ask about the corrosion. This is just the first part of the tub questions I have. Frame was crispy as hell hence I went with a new galvy deal. My guess is the aluminum corrodes a lot quicker once the steel gets rusty. It seems where the steel was in good shape the aluminum was decent. I have a solid pile of stuff to go to galvy and I am going to paint the aluminum as best I can (POR-15 I am thinking of right now).
Old May 26th, 2015, 10:08 PM
DefenderMd's Avatar
DefenderMd
Ben
sounds like you got it for a song. i hope...
i doubt your theory on rust causing other corrosion. I imagine both are corroded by the same process .
Galvanized frames are neato.. but man.. thats a pain! Thought there's a good retirement job. Swapping all those frames for people with attachments to their rovers.
Old May 29th, 2015, 11:42 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Did some "test" work on my left front fender. That had corroded aluminum too - go figure :
Not perfect but should do - I am going to scuff up and paint before installing to help protect the aluminum.
Before:
don's Avatar
don
Don Bunnell
'86 110 3dr ST
After:
1987 LHD Defender 90, refurb. $ 22500 rivermike For Sale - Vehicles 6 September 3rd, 2012 07:06 AM
300tdi - Refurb v. Rebuilt v. Remanuf v. Overhaul??? bjlover Defender Technical Discussions 4 October 9th, 2011 10:36 AM
Picking up a 4.6...refurb notions? o2batsea Defender Technical Discussions 6 August 18th, 2011 10:30 PM
1984 D90 or D110 refurb to 2006 spec DefenderDan Defender Technical Discussions 5 June 23rd, 2009 10:19 AM
Time To Think About Refurb The Wizard Defender Technical Discussions 14 January 4th, 2006 12:59 AM
