Tub Refurb - Page 2 - Defender Source
Old May 29th, 2015, 11:47 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Looking good Don, now to get the tub up to the bench is my troubles. what did you use for filler rod?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 29th, 2015, 12:03 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Haha - I was thinking how I was going to set it up so I could weld. Did a lot of these repairs standing up so tub actually might be easier if I can sit in a chair.
I started with 3/32" ER5356 but that was way too big - then got 1/16" and used a 3/32" tungsten. Tried 1/16" tungsten but I don't know if I was doing something wrong or what but it just wasn't working. 70 amps on the machine.
Old May 29th, 2015, 02:25 PM
Nice. My uncle welded my series tub. He said the best stuff to use was pieces of aluminium cut from other rover panels I had. He used a spool gun. Worked great.
Old May 29th, 2015, 04:11 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Interesting about using Rover aluminum. I might do the Mud UK bulkhead cutout and was thinking of using that aluminum as patch pieces.
Another thing I have found - is the aluminum cannot be too clean. One site I found said to use stainless brushes to prep the metal.
Old May 29th, 2015, 04:38 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
That is very true, aluminum is not as forgiving as steel is when it comes to welding. The brush cannot be used for anything other then cleaning aluminum.
Old May 29th, 2015, 04:57 PM
cbfritz_03
Carmen
none
That's what I did...used spare series panels to repair my tub and wings where they had corroded. I was going to buy all new aluminum but though why... when I had everything I needed already.
Old May 29th, 2015, 05:33 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Hand clean both sides ensuring oil or wax is removed.
Rotary wire brush both sides to remove surrounding paint and heavy oxidation.
Cut out oxidised edges.
Just befor welding (as ally very quickly starts to oxidize) scrup the surfaces with Scotchbrite and a quick wipe with acetone.
If concerned about distortion, try to clamp a heavy copper, stainless, or ceramic block, in intimate contact, to the backside.
Sometimes easier to add an extra layer at the back to avoid blow-through.
Have fun!
Old May 29th, 2015, 06:23 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That's what I read about cross contamination - I labeled them Aluminum.
------ Follow up post added May 29th, 2015 06:28 PM ------
Originally Posted by Whiesel View Post
Hand clean both sides ensuring oil or wax is removed. Rotary wire brush both sides to remove surrounding paint and heavy oxidation. Cut out oxidised edges. Just befor welding (as ally very quickly starts to oxidize) scrup the surfaces with Scotchbrite and a quick wipe with acetone. If concerned about distortion, try to clamp a heavy copper, stainless, or ceramic block, in intimate contact, to the backside. Sometimes easier to add an extra layer at the back to avoid blow-through. Have fun!
Thanks for the tips. They go along with what I have been reading. I noticed the welds were a lot better on my last piece when I did a thorough flap disk -> stainless brush/scotchbrite -> acetone method. And very true about cutting out the oxidized parts.
I haven't used a heatsink yet - seems like the aluminum doesn't warp/move nearly as much as thin gauge steel.
------ Follow up post added May 29th, 2015 06:29 PM ------
My 1/16" filler is actually 4043 - just looked at the reciept.
1987 LHD Defender 90, refurb. $ 22500 rivermike For Sale - Vehicles 6 September 3rd, 2012 07:06 AM
300tdi - Refurb v. Rebuilt v. Remanuf v. Overhaul??? bjlover Defender Technical Discussions 4 October 9th, 2011 10:36 AM
Picking up a 4.6...refurb notions? o2batsea Defender Technical Discussions 6 August 18th, 2011 10:30 PM
1984 D90 or D110 refurb to 2006 spec DefenderDan Defender Technical Discussions 5 June 23rd, 2009 10:19 AM
Time To Think About Refurb The Wizard Defender Technical Discussions 14 January 4th, 2006 12:59 AM
» Defender Registry
CT 25
CamelTM
Trooper
cwilder
Add your Defender
