tub does not sit all the way on to a frame - Defender Source
Old October 8th, 2009, 03:27 PM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
tub does not sit all the way down on to a frame. Only after I lower gas tank.
Possible, I put wires wrong, and it does not let it sit all the way.
Anybody has pictures how wiring should be arounbd gas tank? Or may be it is a different issue?
I went over ECR pictures, it is not clear. Also, where electric wires should come out of the frame, outside or inside towards the tank?
Old October 8th, 2009, 03:38 PM
Can you show us pictures of what you are running into? The tank does push up tight against the tub, but all wiring and lines should be recessed into the grooves on top of the tank.
Not sure if any of these help, but here are pictures of when I dropped my fuel tank
http://lhsw.com/gallery/d90_fuel_tank
perhaps
http://lhsw.com/gallery/d90_fuel_tank/DSC03869 helps?
charles
p.s. Not sure if you saw, but I got your old frame extended and choped for the trailer already!
Old October 8th, 2009, 05:00 PM
ditskovich's Avatar
ditskovich
dmitry
I am confused where to run wires.
Does it exit frame towards tank?
I put mine on top of the tank, and that's probably why it does not let it sit.
Any pictures from underneath of the car?
I'll try to take my tonight.
Great job with the frame!!!!
I am happy it did not just died. Good job!!
Old October 8th, 2009, 05:06 PM
The wires run forward towards the engine alongside the fuel lines. If you look at the picture below the orientation of the tank is as if it fell to the ground from it's mounting place. The wires hookup to the white connector to the right of the fuel lines. They should not interfere with the fit if they run next the the fuel lines (there is an indent there). I'd have to look to see exactly where the wires come out of the harness but it will be forward of the tank for sure. My truck is too dirty to tell right now so it may take a few days to check.
hth
charles
Old October 9th, 2009, 01:12 PM
ditskovich's Avatar
ditskovich
dmitry
thanks, I think pull wires off the frame towards outside, and it lays on top of the tank.
I'll change it and let you know.
Old October 10th, 2009, 12:53 PM
ditskovich's Avatar
ditskovich
dmitry
tub fitting
it was wire laying from the back forward on a tank, I changed that , and everything fall in to place perfectly
Thank you Charles
Old October 10th, 2009, 09:35 PM
Glad I could help. Looking good! Let's have a race to see who can finish our project first. LOL, you'll probably win.
Did you still need to see how the wires run forward of the tank? I got my truck mostly clean underneath today so I could probably take a decent picture now if needed.
Old October 11th, 2009, 02:38 PM
Ronanmd1
Jason
1997 D90 HS2.8
Beer
Charles - Sweet can o' beer bud
Jason
Defender 90 Tub & Frame Wolf Fabrication Wanted 13 September 9th, 2009 10:47 AM
How straight is a typical Defender frame? madcowdungbeetle Defender Technical Discussions 9 August 22nd, 2009 05:43 PM
Rear A-Arm Frame Brackets..etc TDI Guy Wanted 14 February 16th, 2006 09:15 AM
109 Galvanized Frame Coiler For Sale - Parts 1 December 29th, 2005 11:53 PM
tub width on a '94 D90 is tapered "natural"? paulb Defender Technical Discussions 3 August 18th, 2004 07:07 PM
