Trying to trace back temp fan switch connection - Defender Source
Old May 18th, 2011, 03:54 PM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I recently became owner of a 94 D90 V8. Just north of the water pump on the hose there is a switch with a two blade male connection. There is nothing connected to in nor can I find anything disconnected that needs reconnecting. Roversnorth helped me identify that it's a temp fan switch. I'm curious to get into the cooling side because my truck temp gauge will go straight to high heat when at idle after about 20 minutes of driving. When driving, the temp gauge is cooler and I don't get any real heat off the heater either. I'm going to replace the thermostat and refill coolant but I wanted to see if anyone could help me with this plug issue.
thanks
Old May 18th, 2011, 04:11 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
That switch is used for the early AC systems to control the AC condenser fan.
if you don't have AC, it just sits there doing nothing.
Email:
Old May 18th, 2011, 05:12 PM
Matt your symptoms indicate you could have a bad fan clutch. Search on the forums for details but it's easy to test and see, one way being to see if there is any resistance when hot by carefully sticking a rolled up newspaper into the blades while running. If it easily stops the fan, you need a new one.
hth
charles
Originally Posted by pendy
I'm here for the D's
Old May 18th, 2011, 08:33 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Yes, I believe it is the high temperature cut off switch (normally closed) disengaging your compressor clutch.....essentially turning off the AC until the motor cools down.
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old May 19th, 2011, 12:45 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I concur with all of the above.
Sounds like a bad fan clutch is causing your overheating problem. However, if you're also getting no output from the heater..... then also consider the possibility of a big air bubble in the cooling system. "Burping" the cooling system is pretty well covered if you do a forum search.
The temp switch... all modern A/C switches use them one way or another However, if you do an electric fan conversion, it's a very convenient option. Though you do have to change it for that use as the factory LR switch is a bit high of a temp for cooling fans. The good thing is a number of VW's used the same size temp switch, and lower temp options are available. IIRC I'm running a 180 degree switch right now.
-Hans
My oil line fix
My 100k stopped odometer fix
ac, fan, switch
200tdi electric fan switch tomaco1 Defender Technical Discussions 4 July 19th, 2010 06:35 AM
Condenser Fan Switch where is it? Hammertime Defender Technical Discussions 3 August 6th, 2009 11:30 AM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
no lights artm Defender Technical Discussions 9 January 14th, 2004 08:01 PM
Back Door Rattle mdmccallum Defender Technical Discussions 7 December 19th, 2003 12:55 PM
» Defender Registry
Phoenix
Greenbull
White
KGH
Add your Defender
