Trying to Remove Front Door Upper Hinge Bolts - Defender Source
Old June 3rd, 2015, 06:12 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I'm not having any luck removing the front door upper hinge bolts, the side that attaches the hinge at the body, not at the door. Other than they have been painted over by the PO during the last respray, they are more than likely rusted.
I've tried spraying WD-40 on them, but I know that wasn't much help because the spray is not getting to the threads. I've even used a manual impact driver with the proper size bit on it, and the suckers won't budge. They are held by captive nuts and a retainer, correct?
All help, tips, ideas, etc are welcome.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old June 3rd, 2015, 06:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
Drill
Old June 3rd, 2015, 06:18 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
As a last resort, yes. But I'm trying to avoid that for now. I have to remove them and put the same back on, if I can. I'm not rebuilding or changing doors.
Thank you - Samer
2003 Discovery II
Old June 3rd, 2015, 06:19 PM
Yes, held in by a captive nut and like Barry said, drill them out.
Old June 3rd, 2015, 06:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
Drill head off bolt.
Pull hinge off and you can remove the old rusted bolt and captive nut.
Old June 3rd, 2015, 06:23 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Get yourself on of these. http://www.craftsman.com/craftsman-i...8&blockType=G8
If that doesn't work go straight to the drill. Which you will likely be doing anyway. Its a #4 phillips.
Ryan
84 110SW County LHD
07 L322 Vogue
Old June 3rd, 2015, 06:25 PM
At least half of them will need to be drilled. The captive nuts rust solid. Stainless bolts and nuts probably help in the future.
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Barry nailed it. If they're original, they're almost certainly beyond saving. Drill the heads, wrestle whats left out and re-assemble using new captive nuts and hardware. Be sure to use a little anti-seize on the threads to save yourself the same headache down the road.
-Ash
Geared Restoration Co.
352-572-3236
Old June 3rd, 2015, 06:30 PM
bennett's Avatar
bennett
Bennett
'97 Defender 90 Soft Top #1140
I just did this. it took a ton of liquid wrench and some patience. One of mine was seized, but i just used a combination of the right phillips head, a vice grip, and a dead blow hammer. Finally got it out, but wasn't easy.
Do yourself a favor and just drill, then replace all of the bolts, captive nuts, and retainers for all the door hinges with stainless. It'll look much better and you won't have to worry about it again for as long as you have the truck.
Old June 3rd, 2015, 07:25 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
That's exactly what I used, to no avail. The consensus is to drill them out, and that's what I'll do.
Question: I need to replace them with slightly longer screws than the factory size, and will more than likely have to go to a hardware supplier to get those. What size are they? Diameter, pitch and length, anyone know?
Thank you - Samer
2003 Discovery II
Old June 3rd, 2015, 07:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why do you need longer screws?
Old June 3rd, 2015, 07:37 PM
I ordered these and I believe they were a bit longer than stock but I'm not 100% sure.
The Stig Fasteners
Old June 3rd, 2015, 08:09 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
Stig is definitely the way to go. Great vendor. Will work with you to put a package together for your specific needs.
Old June 3rd, 2015, 08:26 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Working on a little project that requires sandwiching a piece of 1/8" sheet metal between the hinge and body.
Do you think that this additional "gap" will have an effect on the way the door lines up and closes?
Thank you - Samer
2003 Discovery II
Old June 3rd, 2015, 09:36 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Use a Philips socket bit on a breaker bar
Old June 3rd, 2015, 09:46 PM
You're going to replace the bolt and the captive nut. Drilling is the way to go.
Old June 7th, 2015, 11:05 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Drilled them out yesterday, and both captive nuts and bolts were rusted. It appears as though they had been replaced in the past, because they were standard sizing not metric, and my understanding is they are supposed to have been 8mm x 50mm fine thread.
Thank you - Samer
2003 Discovery II
Old June 8th, 2015, 08:38 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
were they sae or whitworth? Or just some random pitch metric. regardless, other than the chassis and body, all the parts on the rover (largely and generally speaking) are standard hardware store fittings. Not much specialized in it. Quite possible they put in some not oem bolts. I just ordered a set of SS hardware (non oem standard) to replace my door hinge bolts.
I am able to get all my bolts out but 1. But they were all rusted. The fittings they chose originally are junk. Cheap crappy fittings throughout. I put anti-seize on everything I can get apart on an old truck like this. Especially something japanese or british.
Old June 8th, 2015, 09:40 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I'm not actually sure at this point what they were exactly, but they were stainless and looked to have been replaced prior.
I ordered a new set from Rovahfarm and haven't received them yet. I'll report on them when they get here.
Thank you - Samer
2003 Discovery II
Old June 8th, 2015, 09:53 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
X2 on stig. They are fast and reasonable for metric stainless
Land Rover Defender 4 Cab Door Stainless Hinge Screws (Hex Socket Button)
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
bolts, door
Front Door Hinge Kit for Defender (TD5 Style Heavy-Duty) with Stainless Bolts 89Defender90 For Sale - Parts 6 March 18th, 2015 05:31 PM
Defender td5 tdci RH Upper door hinge new Ben01 For Sale - Parts 0 October 1st, 2012 03:15 PM
How to remove channel to remove seat skins Campbell Defender Technical Discussions 2 October 23rd, 2009 05:47 PM
SW rear door Upper hinge mightymg Wanted 3 October 3rd, 2009 07:17 AM
Stainless door hinge bolts and other rust rustydefender Defender Technical Discussions 28 September 15th, 2007 09:59 AM
