Trundling temp gauge - Defender Source
Old August 5th, 2013, 07:19 PM
D110DC's Avatar
D110DC
Pete
66 SIIA, 70 IIA, 97 D90
So I'm driving the D110DC from Nashville to Jacksonville, FL for the move and find the temperature gauge tends to fluctuate with two inputs: A/C use (which raises it substantially enough that I'm concerned to leave it off the rest of trip, despite 92 degrees outside); and the parking or headlight use (during a few thunderstorms). Pics show the change only between normal 70 mph driving with headlights off and same speed with only change from the headlights on. Anyone want to gander a guess as to why?
ID:	76984   Click image for larger version
Pete
1966 ECR Series IIA
1970 Series IIA (Stella)
1997 D90 ST
2011 LR4 HSE
2010 Range Rover Supercharged
Sadly gone (some more sadly than others):
1983 D110 Double Cab 300 TDi
1989 RRC
1996 D1
2006 LR3
2008 RR
Old August 5th, 2013, 07:27 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Had the same problem with mine. Drove from SC to AZ in July too scared to run the AC past Atlanta!!
Turned out to be wiring and ground related on mine. I swapped in a VDO and new wiring to cure it.
Old August 5th, 2013, 09:16 PM
If the only difference is lights or no lights them bad ground. NAS 110's had a conditioner to fix the reading no matter the input so unless you removed that the gauge reading isn't worth squat!
Old August 6th, 2013, 06:40 PM
D110DC's Avatar
D110DC
Pete
Thanks, guys. Will look for it.
Pete
1966 ECR Series IIA
1997 D90 ST
2011 LR4 HSE
1989 RRC
1996 D1
2006 LR3
2008 RR
Old August 6th, 2013, 06:58 PM
Grover's Avatar
Grover
What engine?
Old August 6th, 2013, 07:34 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
If its like the NAS 110, there is an inline "signal conditioner" just up the wire from the temp gauge that may be picking up the additional power load on the system. Just a guess but removal of this and replacing the gauge is on my short list.
From the ECR website:
http://www.eastcoastrover.com/signalconditioner.html
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old August 6th, 2013, 07:55 PM
D110DC's Avatar
D110DC
Pete
Diesel engine
Pete
1966 ECR Series IIA
1997 D90 ST
2011 LR4 HSE
1989 RRC
1996 D1
2006 LR3
2008 RR
diameter of stock temp gauge naeirie Defender Technical Discussions 2 March 2nd, 2005 06:34 PM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 07:47 AM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
