Truck won't start after washing...Please Help!!! - Page 2 - Defender Source
Old July 22nd, 2010, 02:32 PM
appropriate for Bo Duke's truck
Old July 22nd, 2010, 02:59 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
You know, I once had the Dixie horn in one of my cars...may just have to bring it back!
I think we may have a winner!
http://www.northerntool.com/shop/too...ci_sku=3310301
Old July 22nd, 2010, 04:41 PM
gravitysucks's Avatar
gravitysucks
Andy
94 D90
Originally Posted by Gren_T View Post
... if not make sure the ignition amplifier on the dizzy is clean, dry and has a good earth.
Jeff, mine used to do the same thing. All it would take to fix is a few sprays of wd-40 on the amplifier and it'd start right up. I have since replaced/relocated the amplifier and don't have any more problems.
Old July 22nd, 2010, 07:22 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
+1 for starting fluid
and you can do this with the left-overs :-)
http://www.metacafe.com/watch/yt-aJp...pipe_spud_gun/
Old July 22nd, 2010, 07:58 PM
It was just flooded
Old July 22nd, 2010, 08:48 PM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
sweet!
Originally Posted by cgalpin View Post
It was just flooded
Steve B-
Otterberg, Germany
"Walk tall, kick ass, learn to speak Arabic, love music and never forget you come from a long line of truth seekers, lovers and warriors."
- Hunter S. Thompson
Old July 22nd, 2010, 09:38 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
check under the passenger seat to see if it's wet. had a ST some time ago- snow got in through the top/ door gap and onto the seat; it melted and found its way to the ECU, with similar results to yours. Probably a stretch, but worth a look.
Old July 22nd, 2010, 10:10 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
All is well now and thanks to all who chimed in. With the gas pedal to the floor and about 10-15 seconds of cranking she started and blew some white smoke for a few minutes. I had to keep it up around 1500-2000RPM for a minute or two and then she mellowed out and settled back in.
Special thanks to those who thought of the flooded remedy as I would have spent countless hours and dollars fixing this problem but never would've thought of that! Also thanks to Charles for lending a brother a hand and not laughing at me too much for starting all this fuss over a flooded engine...it helped that I kept putting beers in his hand!
Old July 23rd, 2010, 02:03 PM
jijalicious
Jiman Khosravan
'94 D90
Question
So let ME get this straight...
I see pictures of some D90/110s in mud filled water... 4 feet deep.. which tells me the driver's feet and the entire cabin would probably filled with water and mud...
But then... just by power washing the car.. it floods?
Am I missing something?
Is the car like.." Hmmm clean water.. YUCK. Flood. Yummmmm Muddy Water! ok run!"
~Ji
Old July 23rd, 2010, 02:30 PM
Well, there is at least one difference - pressure. I sprayed my engine bay down with a garden hose, including all the electrical components and never have a problem - but have been stranded at a car wash more than once after carefully using a high pressure washer.
Old July 23rd, 2010, 02:57 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I was told by someone that if you are going to pressure wash, then you should leave the truck running...unfortunately this didn't come until after I had my problem. Can anyone confirm or deny this?
Old July 23rd, 2010, 03:19 PM
How about not pressure washing it?
Old July 23rd, 2010, 03:24 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I think I will refrain from using it in the future but was just curious. Seems that it would make sense that the heat generated by the engine and connections having spark present would be less apt for failure.
Sadly I didn't even spray directly onto the engine but now I know to keep it far far away...like aimed at the siding on the house!
Old July 23rd, 2010, 03:30 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
After SCARR, I took my truck to the car wash to rinse the major mud pieces off. I left the truck running and it stalled while washing. I found some water in the boot of the lead that runs from the coil to the distributor. Dried that out and it started and ran fine. Later, the starter solenoid failed intermittently because of the mud. Ended up replacing the starter.
In the future, I'm just going to use a garden hose, Dawn detergent and a boar's hair brush with a long handle to clean the engine bay. It took three cleanings to get the bay looking clean again.
Old July 24th, 2010, 12:43 PM
easy engine flooded Fix (from the drivers seat i might add)
1) unscrew fuse box knobs and remove cover
2) pull fuel pump fuse
3) crank - normally it will start right up with the gas in cylinders
4) reinsert fuse
5) replace fuse box cover
In my experiance if it is flooded then holding the gas down either A) works or B) insures there is no way it will start for a few days without doing the above steps.
it does not happen often but when it does takes about 30 seconds to fix.
Plus you can pull that fuse and your truck won't run very far if your parked in a iffy place.
95' D90 - daily driver..
start
Mikes truck on the trail????? scoloco Trips, Trails and Events 20 October 27th, 2005 10:21 PM
90 Truck Cab and 3/4 canvas top ronward Misc. Chit-Chat 4 August 11th, 2004 11:00 AM
Does Rhino-lining de-value a truck... JimC Misc. Chit-Chat 18 June 29th, 2004 11:41 AM
Parabolics for a series truck TDI Guy Misc. Chit-Chat 8 May 15th, 2004 11:43 PM
