truck wont start - Defender Source
Old October 11th, 2008, 02:51 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
truck wont start
truck was running, changed plugs, rotor arm , air filter and fuel filter now it wont start, just pops out the tail pipe, not backfiring. any ideas
3rd low and BOOT IT
Old October 11th, 2008, 03:03 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Crappy ignition parts? Pulled wire off of coil for fuel injection? Check for spark-then check for injector pulse-then fuel pressure
legend in my own mind
Old October 11th, 2008, 04:05 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
it's silly but, firing order correct??
This is where I'm supposed to write something witty and funny; or something.
Old October 11th, 2008, 05:01 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
x2. That or you shifted the plugs on the cap so the timing is off. I did that on the Range Rover once. It would pop and I couldn't turn the distributor far enough to get the timing right. I didn't realize I had shifted all the wires over!
Old October 11th, 2008, 06:10 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
firing order correct, gas getting through, spark plug in the coil wire gets a spark, no spark out of distibutor. i didn't have the rotor pushed down far enough the first time and the cover rocked as i turned it over, got it right now. the rotor is very loose, lifts on and off very easily.
i am useless when it comes to the engine.
3rd low and BOOT IT
Old October 11th, 2008, 07:43 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Put the old rotor on. Where did you get the rotor from?
Old October 11th, 2008, 08:05 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
advance auto
$12 there abouts
3rd low and BOOT IT
Old October 11th, 2008, 08:13 PM
All man...
Old October 11th, 2008, 08:41 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Thats your problem. The local autoparts store makes very poor parts for these truck as far as cap and rotor. Put yourold parts back in. And order from AB if you want to save money. I would get OEM from LR or Rovers North myself.
Old October 11th, 2008, 08:56 PM
AB usually sells me the "OEM" stuff, Ive never been happy with it. Same "OEM" stuff the local parts house has. Genuine from Roversnorth cant be beat.
Old October 11th, 2008, 09:12 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Take pictures of the parts and post them here as a warning to others.
Old October 11th, 2008, 09:28 PM
budz
sal gorriceta
various rovers
jimmy, i have used low mileage rotors from RN and you can have it. pm me your address.
sal
Old October 12th, 2008, 09:02 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
put the old rotor back in, still won't fire, checked all wires for connection. the air filter is a K&N, cleaned and oiled it, can you over oil it. still just popping as i turn it over.
3rd low and BOOT IT
Old October 12th, 2008, 10:57 AM
cellulararrest
Chris Snyder
did you put the old cap back on too? Genuine on both cap and rotor is the only way to go.
Old October 12th, 2008, 11:07 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
never changed the cap, looked pretty new. any chance of knocking the timing out changing the rotor.
undone the fuel union just behind the engine, turn key and gas pumps out but not smelling it at the tail pipe
3rd low and BOOT IT
Old October 12th, 2008, 04:14 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Was the rotor difficult to remove? Sometimes you can pull the guts of the advance weights apart pulling up on the rotor. But you said you had spark at the coil but not the wires?
Old October 12th, 2008, 04:28 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
very difficult, soaked it in wire dry, took about 2 hrs before i could pull it. take the coil wire from the distibutor and insert a spark plug i get a spark, take one off a plug from the dis and insert a plug. no spark
3rd low and BOOT IT
Old October 12th, 2008, 05:04 PM
pendy's Avatar
pendy
jim pendleton
89'd90
When you twist the rotor does it spring forward and then return back to its original postion? Does the distributor cap have a black spring loaded contact that is coming down to meet the tab on the rotor button? Sometimes the contact on the disributor cap will fall out of a well used unit.
Hope this helps-
Old October 12th, 2008, 05:21 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
1, no, got to keep twisting to get to lowest position, at times can't get distributor cap on right,
spring loaded contact is coming down
3rd low and BOOT IT
Old October 12th, 2008, 07:28 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Leave the distrib cap off and have someone crank the engine to verify the rotor is turning while trying to start. That may be your problem.
start
Hardtop for a Series truck jvelador For Sale - Parts 0 February 9th, 2006 06:32 PM
And I thought the D-90 looked like a dump truck! OCD90 Misc. Chit-Chat 0 September 16th, 2004 07:40 PM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
90 Truck Cab and 3/4 canvas top ronward Misc. Chit-Chat 4 August 11th, 2004 11:00 AM
