truck wont start - Page 2 - Defender Source
Old October 13th, 2008, 06:47 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
rotor is turning,
3rd low and BOOT IT
Old October 13th, 2008, 08:03 PM
Jimmy, the popping out the exhaust sounds like the firing order is off to me. I know you didn't replace the wires, but double check the firing order. Are you sure you are putting the cap back on the same way?
Old October 13th, 2008, 08:37 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
double checked the firing order, OK. cap on the right way. was spluttering, missing ect before i replaced plugs rotor ect. can turn the rotor 1/4 turn and it dosn't spring back, can also lift it 1/4".
3rd low and BOOT IT
Old October 13th, 2008, 08:45 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
What about the plugs you replaced? Gapped improperly or something? Doesn't seem like that should cause it to not start at all, but worth a shot since it sounds like the distributor is working properly.
You checked to make sure spark is going in and coming out of the distributor correctly? Does the popping get worse/better depending on how you spin the distributor to adjust timing?
Old December 3rd, 2008, 10:55 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Well this is what was wrong;
1)Find Distributor to be damaged beyond service
Replace distributor and reset ignition timing
replace distributor cap and rotor
2) further testing of tune state indicate very poor
spark from ignition coil
replace ignition coil and wiring terminals
3)further testing indicates multiple missfires
replace spark plug HT wire set
4) further testing and CEL (Check engine light)
indicates high idle due to open circuit IAC
(Idle Air Control..."stepper motor")
replace stepper motor
5) Further testing and failure to start (intermittent)
with further CEL codes indicate a failed input to ECU
Diagnose poor ground connection at ECU plug ground pin.
repair ground pin
repair burnt ground wires at rear of engine
and subsequent damage to injector wires
I didn't figure it out, had to take it to the biggest and best Rover shop in Elliott Maine
3rd low and BOOT IT
Old December 3rd, 2008, 12:01 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Woowww.... That's a long list.... Are those the cause of the issue or consequences or is it too early to tell?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 3rd, 2008, 01:44 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
running fine now, everything just seemed to shit the bed at once
3rd low and BOOT IT
start
Hardtop for a Series truck jvelador For Sale - Parts 0 February 9th, 2006 06:32 PM
And I thought the D-90 looked like a dump truck! OCD90 Misc. Chit-Chat 0 September 16th, 2004 07:40 PM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
90 Truck Cab and 3/4 canvas top ronward Misc. Chit-Chat 4 August 11th, 2004 11:00 AM
