Truck leaking at capping - Defender Source
Old January 13th, 2010, 12:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
So my 110 is for the most part water tight. Ha!!
Well the doors and roof aren't leaking but I have two spots where water trickles in through the capping. One on each side. In an ideal world I would remove the roof, galvanize the capping and reseal everything but in that ideal world I would have a new 110 and a secretary would be typing this on my lap. Since none of that is happening, how can I seal the two capping leaks before it does real damage? Can I squirt sealant into it on the inside?
Any help appreciate.
Old January 13th, 2010, 01:05 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Where exactly are your leaks located? Rear tub corners? I had a whole lot of Moab dust blow in there on my last trip. I would like to seal it with Silicone or something to prevent that.
Old January 13th, 2010, 01:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
one side close the back of the rear seats
other side close to the back of truck.
Old January 13th, 2010, 03:36 PM
GYM's Avatar
GYM
Gary
97 SW
Yes. I had the same trouble, same exact spots on one of my trucks.
I used a combination of sealant and a strategically stuffed scrap piece from my mobile Rover weatherstrip emergency pack, (aka: a dazzling array of different size Home Depot window weatherstripping rolls) to cure the problem.
Old January 13th, 2010, 04:17 PM
bjf's Avatar
bjf
barry f
94 ST #395
yeah I am thinking dum dum strips
Old January 13th, 2010, 04:19 PM
tighten the nuts holding the roof on to the cappings and adjust it so it fits properly and it should fix the leaks.
Old January 13th, 2010, 04:22 PM
bjf's Avatar
bjf
barry f
94 ST #395
well how loose could it be? I assumed the age of seals was doing it?
should i tighten all capping bolts?
Old January 13th, 2010, 05:10 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
When I re-did my headliners I went ahead and tightened all of the bolts and I was amazed that some of them were really loose. After I had them all really tight that solved a lot of my leaks. Still have to seal the roof with sealant though.
Old January 13th, 2010, 05:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
Cool will try that. I was shocked my roof doesnt leak. Been driving with no headliner and I did a hose test.
Old January 13th, 2010, 05:43 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My roof is fine but I have a leak somewhere on the bulkhead or toe boxes (mostly passenger side). I can't figure out where, I suppose I need to take it apart. When it rains really heavy I get water on the floor mats and it seems to be coming from top portion of toe boxes or above somewhere.
Old January 13th, 2010, 05:52 PM
bjf's Avatar
bjf
barry f
94 ST #395
check your vents
Old January 13th, 2010, 08:29 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Ah, the vents! Perhaps the seals?
I will do a water hose test.
check your vents
A Great Read... CDN90 Misc. Chit-Chat 6 December 16th, 2009 12:25 PM
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
body capping on rear tub WhiteD90 Defender Technical Discussions 5 October 6th, 2004 06:10 PM
Rusty Capping dbwitt Defender Technical Discussions 2 February 14th, 2004 05:32 PM
