Truck Died on Hwy, Wont Restart. - Page 2 - Defender Source
Old May 16th, 2016, 08:16 PM
carlosz's Avatar
carlosz
Carlos
replace fuel filter, check coil and amplifier output, check tps sweep.
diagnose systematically do not jump from one component to another with out verifying proper operation of each and everyone of the components involved.
there is no magic way of simply pinpointing to a failure with 100 percent success with out testing.
good luck...
Old May 16th, 2016, 08:24 PM
Originally Posted by carlosz View Post
replace fuel filter, check coil and amplifier output, check tps sweep. diagnose systematically do not jump from one component to another with out verifying proper operation of each and everyone of the components involved. there is no magic way of simply pinpointing to a failure with 100 percent success with out testing. good luck...
Yeah you kinda missed the 4 hrs of systematic troubleshooting (install/test/the-install) on all the parts we tried
All those bits were swapped (except amp module since it "could " be bad) and the the original bit was out back in.... Some of them we pulled from my truck which is working fine as well..
In another life, I ran a test group..
95' D90 - daily driver..
Old May 16th, 2016, 08:41 PM
Basically it floods (current thinking) when throttle is applied but also after 1-2 minutes at idle.
Any sort of non gradual throttle kills it.. Almost like the computer thinks it is at full throttle all the time
TPS was swapped with my old one, which was good, I swapped it thinking it may have been the culprit for my stalling issue (now resolved), it wasn't... And is fine.. There is not much else to look out other than cap/rotor/amp module in the ignition circuit since all other senders are fine (maybe coolent temp sender? Which has not been swapped out) but we can pull mine which is new to test)
And I guess the MAF, since I have a new one
Old May 16th, 2016, 09:03 PM
exmod110's Avatar
exmod110
Don Lang
Does it have cats on it?
85 exmod 110 rhd 300tdi
Old May 16th, 2016, 09:08 PM
Mine died under similar circumstances. Had been doing 80 with three guys, weekend worth of gear, and a dog in the truck.
Turned out to be a carbon tracking on rotor sending the juice from the coil down the distributor shaft instead of out to the contacts on the cap.
Old May 16th, 2016, 09:10 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I have relatively new cats. Coolant temp sensor is pretty new. Fuel temp sender is original
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old May 16th, 2016, 09:11 PM
Mine died under similar circumstances. Had been doing 80 with three guys, weekend worth of gear and a dog in the truck. Turned out to be a carbon traced rotor sending the juice from the coil down the distributor shaft instead of out to the contacts on the cap.
That is a great lead... And cap/rotor/clean are next up on the list
Yes it has cats as well..
Old May 16th, 2016, 09:13 PM
Cleaning won't cure carbon tracking. Swap em out
Old May 17th, 2016, 10:23 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Issue resolved. Pulled the rotor and it was toast. I assumed it wasn't the rotor since it wasn't running badly before.
1995 Defender ST
1996 Discovery SE7
Old May 17th, 2016, 10:24 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Internal
1995 Defender ST
1996 Discovery SE7
Old May 18th, 2016, 08:09 AM
Must be nice to pull up on your rotor and not have your entire distributor shaft/springs come up with it.
Old May 18th, 2016, 09:11 AM
Cool, same issue as mine.
Old May 18th, 2016, 09:25 AM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Doug,
I assumed the rotor would go gradually. I assumed the truck would start to run rough before it quit. Did not know they could just fail.
1995 Defender ST
1996 Discovery SE7
Old May 18th, 2016, 09:35 AM
Doug,
Mine died with no warning late @ night @ that light in Kinston @ the Skinners By Pass.
It had been running fantastic. Fortunately the all night gas station sold beer so
We drank for an hour and a half waiting for my brother to come up from Harkers.
Old May 18th, 2016, 12:16 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Congrats and you win a $.
Old May 18th, 2016, 01:14 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Excellent news.
Please go back and read post number 2.
I think you should do all 3 if you haven't already.
RDavisinVA
Old May 18th, 2016, 02:17 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
What is the recommended source for rotors? I've received mixed signals re the new ones packaged as Lucas but made by someone else. Is there anything better?
Old May 18th, 2016, 02:37 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I have heard that Powerspark red rotors from the UK have good.reviews
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 19th, 2016, 09:46 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I've used both.
Never had a problem with either.
Comparison, at Rovers North Genuine Cap($60) and Rotor($30) versus Proline(Allmakes?) Cap($18.50) and Rotor($8.50)
Someone compare them side by side and show me the quality difference in the Genny??
The one thing I learnt years ago is dont muck it up by pulling the rotor off-- crack it and break it loose.
Put a little grease in the new one and change it every coupla years.
Dagone.
Rent my
Old May 19th, 2016, 09:52 AM
search and you shall find....
http://www.defendersource.com/forum/...-lr-51547.html
i did this a while back - the OEM one is made substantially better/thicker than the proline/lucas ones.
im not sure it actually effects anything but i change them fairly often anyway..
start
Rough acceleration when Hot... won't restart if I stall her jijalicious Defender Technical Discussions 4 May 4th, 2012 06:59 PM
Spotted on Hwy 395 yellow 110 kellymoe Misc. Chit-Chat 0 September 16th, 2009 11:52 AM
300tdi died won't restart discotdi Defender Technical Discussions 2 August 3rd, 2009 10:17 PM
90 Stalled and would not restart bjf Defender Technical Discussions 33 April 11th, 2009 12:28 AM
Won't Restart After Burying coast_rider Defender Technical Discussions 7 September 9th, 2004 12:44 AM
