Truck died in garage - is there a way to take it out of park? - Defender Source
Old February 25th, 2012, 05:53 PM
RedD90's Avatar
RedD90
JNH
'97 D90
I accidentally left my parking lights on my'97 D90 the other night and consequently, have a flat battery. The truck is stuck in the garage and there's no room to pull a vehicle in alongside it to jump start it.
Alas, I was compelled to ask for roadside assistance via the CAA. Of course, his truck has everything needed but when he hooked up his extra long jump leads, he couldn't get it to start. The battery is about a year old and aside from my stupidity in leaving the lights on, the vehicle starts first time, every time. Despite the CAA chap making several calls and trying a few different things (checking leads, fuses etc), he couldn't get it to turn over.
Does anyone know if there's a way to take it out of park so that we can push it out of the garage and have it towed to my mechanic or am I completely knackered? The headroom is tight, so there's no way he can hook it up and drag it out.
Fingers crossed that someone has an idea here or I'll have to plead with my mechanic to come out to my place.
Hicktonite
Old February 25th, 2012, 06:44 PM
A battery charger or jump leads should provide enough voltage to operate the park interlock solenoid. Then put it in neutral so you can roll it out and put a proper jump start on it. Or, battery charger etc.
Did the same thing this AM with my neighbor's Honda Element.
Old February 25th, 2012, 06:58 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Couldn't you just swap the battery?
Old February 25th, 2012, 07:20 PM
Buy a new battery and swap it in. Failing that, can you move the t-case shifter into neutral (probably not, but worth a try)?
Worst case, you can pull both driveshafts (note you will have to jack up a wheel or two to rotate the shafts to get to all the bolts) or pull the PTO cover on the T-case and remove the input gear (what I would do).
Old February 25th, 2012, 07:59 PM
RedD90's Avatar
RedD90
JNH
'97 D90
Thanks guys! I have checked a few things out and noted the following:
All lights come on with the exception of the brake lights. Could be that the brake light fuse and/or the brake light switch have gone? Could this be why we can't get the starter to even tick when trying to start? Will have a go again tomorrow morning but the advice on shifting gears is extremely helpful should it be necessary to get it to my mechanic who's luckily just up the road from me.
I'm hoping I don't have to get underneath the truck and fiddle with bolts. I'll report back tomorrow when I take a fresh look at things and sober up.
Hicktonite
Old February 25th, 2012, 09:42 PM
If the brake lights do not go on, jump the brake light switch.
http://www.roverparts.com/Techtips/C...ut_of_park.cfm
Old February 25th, 2012, 10:07 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Or you could just borrow a similar size battery from a friend.
Old February 26th, 2012, 07:17 AM
LRover's Avatar
LRover
J. Michael McCaig
If the brake light fuse is blown it, won't crank.
Old February 26th, 2012, 08:03 AM
KKilo23's Avatar
KKilo23
Kenny
It is a blown fuse most likely. There is a 15A fuse that controls the shifter lock and starter. It is behind the little panel in front of the CDL.
Read this thread... I had an issue with my turn signals blowing this fuse... it should help....
http://www.defendersource.com/forum/...highlight=fuse
Old February 26th, 2012, 10:35 AM
RedD90's Avatar
RedD90
JNH
'97 D90
I'm deeply appreciative of the D-90 Community coming to my rescue. My lad and I, in-between watching Arsenal slaughtering Spurs and hopefully Cardiff doing the same to Liverpool will check the known electrical faults highlighted here and in the other thread that Kenny provided to get my problem sorted out. Will report back as and when we source the problem and fix same. Thanks!
Hicktonite
Old February 26th, 2012, 03:38 PM
RedD90's Avatar
RedD90
JNH
'97 D90
This !!!
Thank you! KK! The reason why it blew is because the rear driver's side brake light lamp housing was full of water, the connectors having rotted as a result. We got those fuses that light up when they blow (really useful, them!) and only by chance with my son standing behind the vehicle while I backed it out of the garage and applying the brakes did he notice the brake light not illuminating.
Sometimes it pays to work in teams! Ha ha!
Anyhow, I'm going to bite the bullet and get myself a set of LED lights for the back. While I was checking the connectors, it is obvious that it's not only the bulb-side connectors that need changing out but the receiving-side too. Anyone know if the LED sets have these included or will I need to replace these with stock connectors?
Thanks for everyone's input and help. I've copied this reply to the original post just so that there is a link between these two helpful threads.
Hicktonite
Old February 26th, 2012, 03:43 PM
RedD90's Avatar
RedD90
JNH
'97 D90
Thanks Jeff! Where are these? Ha ha! Sorry mate!
Dont forget to yank out the solenoids!
-Jeff
Hicktonite
Old February 26th, 2012, 04:19 PM
RedD90's Avatar
RedD90
JNH
'97 D90
Cheers fella!
Hicktonite
Truck randomly dies... dlane Defender Technical Discussions 12 July 20th, 2011 12:23 PM
Cleaning Out the Garage Two woldd90 For Sale - Parts 11 January 13th, 2006 10:09 PM
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
Superlift ORV Park in Hot Springs, Arkansas Nov. 20-23 Joe B Trips, Trails and Events 5 November 12th, 2003 10:07 AM
