Troubleshooting: Turn Signals and Flashers not Working - Defender Source
Old January 25th, 2016, 12:17 PM
LRColorado
1990 Defender (200 TDI)
Yesterday noticed my headlights work, but not my turn signals or any other lights on the exterior.
The lights are newer LED. Need help from the forum on the top 3 steps to begin the troubleshooting process. I have already checked the fuses and they are fine.
Not sure if this matters, but the same day i replaced two burned out dash bulbs so had that area of the dash apart for 20 minutes while changing out the bulbs.
Old January 25th, 2016, 12:36 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by LRColorado View Post
Yesterday noticed my headlights work, but not my turn signals or any other lights on the exterior. The lights are newer LED. Need help from the forum on the top 3 steps to begin the troubleshooting process. I have already checked the fuses and they are fine. Not sure if this matters, but the same day i replaced two burned out dash bulbs so had that area of the dash apart for 20 minutes while changing out the bulbs.
Ground; I had the same issues until I replaced my light grounds with a bus bar and a direct link to the battery negative. I'd start there, bus bars are cheap
Old January 25th, 2016, 04:29 PM
LRColorado
Thanks JT.
Does each light have an individual ground where it is located on the truck or is there one ground back in the engine area? Exact location would be helpful.
Did you mount the bus bar in the engine area?
Old January 25th, 2016, 04:48 PM
87 D110 (Ruby)
Also try your headlight switch arm - if you get no dash lights, chances are your other lights don't work - those things are fidgety, you can have headlights, and no dash/rear lights....generally a ground issue though
Old January 25th, 2016, 05:41 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Thanks JT. Does each light have an individual ground where it is located on the truck or is there one ground back in the engine area? Exact location would be helpful. Did you mount the bus bar in the engine area?
I mounted a blue sea bus bar right above where the harness goes into the firewall.
After that I tracked the headlight looms back to where there was a splice and I cut them and re ran them to the bus. I took a 12 gauge wire and ran it to the bus under the body and into the battery box.
Planning a blue sea terminal there as well for my aux heated seats and my eventual radio.
I also bought new steering column switches for everything (even the fog light switch I no longer use) just to be safe.
I think I may re-run all lights on relays this spring, but for now it was a sure fire fix
------ Follow up post added January 25th, 2016 05:49 PM ------
sorry, yes, all lights should have individual grounds. I found that if I leaned on the light housings they would ground on their mounting screw. It wasn't super reliable for me so I just re-ran the grounds to be safe.
Honestly if I had to wire a defender id do it like a boat and isolate everything. Common loom be damned
signal
NAS Headlight Bezels, Turn Signals and Parking Lights bradfordish For Sale - Parts 4 December 11th, 2013 01:45 PM
Turn signal & hazards not working - trailer light on Howski Defender Technical Discussions 14 November 9th, 2013 02:26 AM
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
Turn Signals (rears work, fronts don't) cmcarp Defender Technical Discussions 2 September 5th, 2006 04:55 PM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
