Trouble with Trailer Lights - Defender Source
Old July 7th, 2008, 09:24 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
Have a 94 D90 with Land Rover trailer light plug and adaptor to use my flat 4 trailer plug. Checked adaptor with test light and all worked correctly. Plugged in trailer and things went goofy. First thing I noticed was D90 backup light came when any of the other lights came on. Both turn signal lights on trailer blink very dimly when either the right or left turn signal was activated. Running lights on trailer very dim when lights of D90 truned on. Brake lights seem to work OK except D90 backup light comes on.
Any Ideas?
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old July 7th, 2008, 09:35 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Well, if it tested alright with at the back of the car, you might find the problem is a short in the trailer wiring, especially if this is a boat/pwc trailer that is being submerged in water frequently. I would clean up the connections and check the trailer lights for corrosion inside of them. Do you have another vehicle you can connect the trailer to to see if it acts the same way?
Old July 8th, 2008, 08:20 AM
The Wizard's Avatar
The Wizard
Douglas Wozny
The trailer lights work OK when hooked up to my '74 CJ5 and my neighbor's car.
The Wizard
Old July 8th, 2008, 05:08 PM
Check the ground wire. I forget where it is on a 1994, but that was my issue when I had the same problem. IIRC I just grounded the wire directly to a cage bolt.
Old July 8th, 2008, 09:03 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
Evilfij,
What ground wire I am to check? The one on the vehicle's trailer light plug or the main vehicle ground?
If the ground is bad, why does the test light work? Just can't figure out why plugging the trailer in makes things go goofy.
The Wizard
Old July 8th, 2008, 10:47 PM
I would suspect a ground issue with the 7 pin socket if the back up light comes on when the brakes are applied- but only when the trailer wiring is pluged in, since the 4 prong adapter has nothing to do with the back up light. Or possibly a short in the adapter.
Old September 21st, 2008, 05:55 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
Finially got up the courage and found time to look behind the rear passenger side speaker where the "box" for the trailer connector is located. Going out of the "box" there are four wires: white(ground), brown (tail/parking), green (right turn/brake) and yellow (left turn/brake). Wires going into the "box" are white, yellow, black and green. The white is connected to 2 green/brown wires. The black is connected to 2 red/black wires. The yellow is connected to 2 red/green wires. The green is connected to 3 wires: a large gauge green/purple wire, a small gauge green/purple wire and a red wire. Not sure what the "box" does as four wires go in and four wires come out but I guess it does something.
Evilfij and Maryland 110 talk about grounding issues. Can anyone elaborate on that. From what I can see everthing is fine except when I plug in the trailer. And the trailer look fine with other vehicles. It is a simple circuit. It is not like I am working on a super collidor. HELP!
The Wizard
Old September 22nd, 2008, 03:43 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
The box is most likely a converter to go from the rover set up with a separate brake light and turn signal light to the trailer which uses the same bulb for brakes and turn signal.
As for the ground comment, that is most often the problem, I've had with trailer wiring. They sit for long periods of time and quite often the ground connections at the tail lights etc get corroded. I would suggest you start at the back end of the trailer and check every ground connection. You said it worked with other vehicles. If you're sure of that, and it is recent, then I would check the ground connection between the trailer and the tow vehicle. As a last resort, it may be the little black box, however, I don't think I've ever had one go bad on me.
Old September 22nd, 2008, 07:54 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
What you really mean is "Euro style" to "US Style" wiring!
The old Euro trailer plug had 7 pins (the new standard is 13 pins).
MonLand
1995 D90 NAS
1996 Discovery NAS
ht, lights
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Trailer lights hook up question thewap Defender Technical Discussions 12 November 24th, 2006 02:16 PM
7000lb Trailer Roadsiderob Defender Technical Discussions 18 January 20th, 2006 11:29 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
