Trouble Starting in the Rain - Defender Source
Old January 19th, 2004, 11:23 AM
Matt Klapmust's Avatar
Matt Klapmust
Matthew Klapmust
'94 D90 ST
I am a D-90 newbie and have encountered a small problem. It starts just fine in the cold but apparently rain causes problems with the ignition. The ignition fires but the engine won't turn over. Any suggestions? I hate having to metro to work on mornings after it has rained....
Old January 19th, 2004, 12:03 PM
Public transport is good. How many miles. Have you replace your dizzy cap? thats where i would start i had some hesitation when it gets wet and muggy out a new dizzy helped me.
Old January 19th, 2004, 12:40 PM
What do you mean by this?? Is the starter not turning the motor? Or is it cranking and not fireing?
If its not firing check your cap and wires for corrosion and water.
If its not turning over check that your relays are dry.
Old January 19th, 2004, 04:17 PM
Matt Klapmust
Matthew Klapmust
'94 D90 ST
Its got about 45K miles. Checked the dist. cap and all the wires and they looked clean. Added some dielectric silicone to all the connections just to make sure.
Its firing as in the spark plugs are firing, but just not turning over and running on its own.
Again, this only happens when it is wet out. Starts fine in cold weather.
Old January 19th, 2004, 04:44 PM
Still a little puzzled but I think I figured out what you mean. When you say it's not turning over, you mean the starter is turning the motor but the engine is not firing up. If you have good spark then you may not be getting fuel. Your fuel pump may not be getting power, check the relay, the fuse, and the wires. Most likely the wire going to the pump is shorting to ground when it gets wet.
Old January 19th, 2004, 04:53 PM
Matt Klapmust
Matthew Klapmust
'94 D90 ST
Thats exactly it. I appreciate the help. Now to check the forecast....
start, starting
Starting problem (occassionally) kolvedic Defender Technical Discussions 21 January 21st, 2012 11:12 AM
trouble starting tuscany Defender Technical Discussions 3 August 3rd, 2007 04:52 PM
Not starting '95 what to check next. jcasteel Defender Technical Discussions 17 June 10th, 2005 02:38 PM
Rain Cover / (more) portable windows Antonios Wanted 2 May 28th, 2005 07:01 PM
Help with engine not starting cbass Defender Technical Discussions 4 April 5th, 2005 12:12 PM
