Trouble Shooting Wipers - Defender Source
Old October 27th, 2013, 06:00 PM
Nate6472/
Nate
88 D90 V8
There are 3 leads on the wiper motor. I jumpered pwr to each one at at time and nothing happened. Ground is good. Fuse is good.
Wipers worked and hit my LED Light bar and then did not work since.
Thanks for help.
Old October 27th, 2013, 06:58 PM
Interesting way to troubleshoot something .... would you test for gasoline by throwing in a match?
Fortunately you've probably only blown a fuse ...
Old October 27th, 2013, 07:05 PM
Nate6472/
Nate
88 D90 V8
NO I would not test gasoline with a match. Applying power to the leads on an electric motor seemed logical since the fuse was good.
Trouble shooting an electrical short. Baldewin Defender Technical Discussions 8 August 12th, 2012 09:03 PM
wipers overrun artm Defender Technical Discussions 18 February 26th, 2009 01:32 AM
Any 3rd party windshield wipers? cdnpaul Defender Technical Discussions 36 April 27th, 2008 09:36 PM
Windscreen wipers TDI Guy Defender Technical Discussions 22 December 2nd, 2004 12:41 PM
Windshield wipers not functioning properly cdnpaul Defender Technical Discussions 1 November 10th, 2003 02:52 PM
