Trouble replacing Alpine window seal - Defender Source
Old July 31st, 2016, 10:27 AM
bnoonan
Brice
1988 RHD 90
Hello all,
The rear quarters were easy. I watched the only alpine video I could find on YouTube, but it was on a Disco (those windows appear to be far easier to seat).
I've encountered a few recommendations on how to get these in, but all were exceptionally brief (so brief that I'm not certain I follow).
From what I've gathered:
1) wrap seal around window
2) put string/twine inside channel around seal (where the roof rim will go)
3) Set in place (as much as possible? may be able to get much of bottom set)
4) Have helper hold firmly in place from outside
5) from inside pull string at right angle to the window around the seal through window opening. it will pull the lip of the seal inside the window.
(some appear to grease the rubber with baby oil or spray silicone)
(a Lisle 47000 tool appears to be very helpful getting the bead in....mine will be here in 2 days)
Since I've got 2 days until my Lisle tool gets here to help me fill the hole in my Defender, I'd much appreciate any insight or guidance on how to best do this.
Old July 31st, 2016, 11:25 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Ditch the string, use a lot of lubrication (soapy water, wd40, etc..), use a couple plastic spreaders, use the channel tool when it comes in, and put a towel on the ground in case the glass slips out of your hand. Getting the glass in place is easy, getting the locking strip in place can be a SOB.
Old July 31st, 2016, 11:32 AM
bnoonan
Brice
1988 RHD 90
Am I correct though that you put rubber around glass, then insert it or would you put seal around hole and try to fit glass into it (that is how I did the back)
Old July 31st, 2016, 11:34 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Rubber in the hole, glass into the rubber.
Old July 31st, 2016, 12:32 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I replaced both of mine when I painted the top. Agree with no string. Place the rubber in the top with the gap on the bottom so water will be less likely to leak (I used a long straight piece of the gasket, not sure if they make a round on to match the hole). I used a screen door roller from Home Depot and a lot of armor all to get the lock strip in. It helps if you keep it warm while working with them. Good luck.
Angus
Old July 31st, 2016, 02:31 PM
rovertrader's Avatar
rovertrader
Dale
Rubber in hole, add spray Pam, set glass, more spray Pam on rubber where lock seats, insert lock...
Old July 31st, 2016, 03:31 PM
bnoonan
Brice
1988 RHD 90
Fantastic. Thanks to all of you for the advice. Much appreciated.
Old August 1st, 2016, 12:59 PM
PTSchram
P. T. Schram
Down to only six!
I use tire mounting lubricant.
Once you get over the fear of the glass breaking (so far, I have not broken a piece of glass on a Rover and have done a LOT of glass work!) it goes pretty well. The Alpine windows are easier than say a rear window on a Disco. Trust me when I say that will make you question your line of work!
Wrench to wheel, wheel to wrench
Old August 1st, 2016, 01:09 PM
rovertrader
Dale
Disco rear door glass is the worst!! I finally gave up and had the glass shop do it, and they said they would prefer not to do any more!
Old August 1st, 2016, 03:10 PM
bnoonan
Brice
1988 RHD 90
The cooking spray and window screen tool suggestions ended up working perfectly for me.
It gets a bit slippery but no real issues.
I:
1) Put rubber around hole in roof, seam at bottom.
2) Set glass into bottom and slid to one side, getting a bit of the top edge within the rubber as well. You can do pretty much the whole bottom and around one end without the cooking spray.
3) Spray and use flat screwdriver to lift lip around other end and top edge.
4) Spray channel with cooking spray and use screen roller tool to get it in.
With the cooking spray it took less than 10 minutes per side.
Old August 1st, 2016, 04:54 PM
rovertrader
Dale
'Slick' trick ;-)
Old August 1st, 2016, 07:02 PM
PTSchram
P. T. Schram
Down to only six!
LOL-right after I started slinging Chrome, my son and I had three in a single week.
We used up all but one of my used rear window glass stock.
By the last, we were pretty good at it, but Boy Howdy I was still nervous as all get out. A big piece of glass with too many curves!
Old December 6th, 2016, 05:25 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
I am making preparations to replace my rear quarterlight and alpine window seals. Not leaking, but starting to show there age.
Where are you guys sourcing your seals? Any better alternatives then $50 a pop for the genuine alpine seals?
Old May 22nd, 2017, 09:04 PM
taylorwilson
Taylor Wilson
93 D110 CSW
Bringing this back to life as I'm about to do this - any thoughts on the best source for window seals? OME VS aftermarket?
ac, window
Alpine window rubber seal zenwithin Wanted 6 February 9th, 2014 12:31 AM
Trouble with Hub Seal moose Defender Technical Discussions 2 May 18th, 2013 11:20 PM
Alpine window seal question egor Defender Technical Discussions 4 December 8th, 2012 11:31 PM
Alpine Window Seal RiftRover Defender Technical Discussions 0 December 14th, 2010 03:26 PM
Alpine Window Seal RyanS Defender Technical Discussions 7 July 31st, 2007 10:19 PM
