Trouble removing front differential - Defender Source
Old January 24th, 2010, 12:56 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I'm having some trouble removing my front diff. Axles have been pulled and I've removed all of the nuts that hold the diff into the housing. I can wiggle it away from the axle about 1/2" but it won't clear the ends of the studs. I think--but I'm not sure--that it might be hanging up on the passenger side of the sway bar linkage.
Rave is useless and just tells me to pull the diff out. If only!
I've tried hosing it down with brake parts cleaner and that helped a little bit but it's still being a bastard.
Any suggestions on how to get this bugger out?
Old January 24th, 2010, 08:39 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Sometimes you have to pry it out with 2 pry bars or big screw drivers. Lever it back and forth. Be careful. Its heavy and you dont want to drop it on your dome while under it.
Legend in My Own Mind.
Old January 24th, 2010, 09:02 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The front is more difficult than the rear I find because of the angle, it sits on the studs and has to be lifted at the same time it is pulled to the rear. It binds up on the studs if you get it canted, I've found it's best to seat it back flush and try again rather than yank on it. You'll get it with a little patience.
Old January 24th, 2010, 10:53 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I just pulled one and had to use a pry bar to LIGHTLY pry on each side and the bottom till it was off the studs enough to pull it by hand.
they just tend to bind if you do not get them pulled exactly straight off the studs
ohh and X2 on making sure it does not fall on you... that hurts
Old January 24th, 2010, 06:08 PM
chris snell
Chris Snell
87 Ex-MOD 110
Thanks guys, that helped. I finally got it off. Had to lower the sway bar to get it out of the way. Diff still didn't want to pull out. My wife Rachel was watching and suggested that I spray the posts on the housing down with "lube". I laughed at the suggestion but doused them with brake cleaner to appease her. Whaddayaknow, the damned thing came right off after that. She positioned the floor jack and lowered it down. What a woman.
Old January 24th, 2010, 06:49 PM
Cool, maybe she can help you stick it back in.
Old February 20th, 2010, 08:41 PM
chris snell
Chris Snell
87 Ex-MOD 110
Well, the GBR thirds came in and when I went to put them on today, I noticed that four of the studs in the housing are too short to make it through the third member housings. I called Bill and he is overnighting me some longer studs on Monday.
Bill says that he's never seen a D-90 with the short studs, but when another local D90 owner stopped by my house, we checked and his has the short studs, too. We both have very early 1994 trucks.
What's the story on this?
Old February 20th, 2010, 08:46 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
FWIW I did notice when I was messing around with a Series housing and D90 diff that the Series studs are shorter.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 20th, 2010, 08:57 PM
Land Rover is retarded. This is now my standard answer for weird stuff like that.
Old February 20th, 2010, 09:18 PM
always nice
Old February 20th, 2010, 11:18 PM
chris snell
Chris Snell
87 Ex-MOD 110
So here is one of the bolts. Out of curiosity, what is the technical name for this type of bolt? I've never seen any like these before.
http://www.flickr.com/photos/defender90/4374189027/
http://www.flickr.com/photos/defender90/4374938142/
Old February 20th, 2010, 11:48 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
looks like a hub stud bolt. don't know how technical that is.
I just did my diffs twice. I put a 10 spline in without looking and then one had a messed up pinion. so I did 4 diffs in two weekends outside in 20 degree weather sucked real bad. I found that if you hit the diff with a small sledge it will unseal itself and will be easy to pull off that way.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 21st, 2010, 12:17 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
It's simply a splined stud 3/8 USNF, pretty much unobtainium unless from LR... I've seen shorties one the outside 4 in trucks up to 99.
Keep in mind in doing Toyota conversions we don't use these, so if you need some guys don't be shy I have a drawer of them.
Keith
Big, Red and ... aaa Red..
Old February 21st, 2010, 12:25 AM
chris snell
Chris Snell
87 Ex-MOD 110
Thanks, Keith, I appreciate the offer. Bill is overnighting me some on Monday. I'm just bummed that I couldn't put the diffs in this weekend.
...another few days of staring at the LongTracks CVs and axles on my bench and dreaming.
Old February 21st, 2010, 12:51 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Horrible... Just horrible! All that waiting!!!!
Actually they're pretty to look at, I keep one next to the bed at night so that I may have nice dreams!
Keith
Old February 21st, 2010, 09:18 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
They sure are perdy...
differential, vin
FREE: D90 Front Drive Shaft and Differential Guts coryhula For Sale - Parts 3 January 6th, 2009 03:54 PM
Removing S/T Front Sliding windows Frankie Carbone Misc. Chit-Chat 3 July 28th, 2008 10:28 AM
Trouble shoot diff with out removing? D90user Defender Technical Discussions 18 November 14th, 2007 07:53 AM
Removing front shocks Trevor Tarr Defender Technical Discussions 5 April 10th, 2005 04:51 PM
