Trouble changing power steering belt, 94 D-90 - Defender Source
Old December 21st, 2003, 06:14 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
They were sqeaking and didn't look too good, so I figure time to change all the belts on my D-90. A quick trip to Napa gets me everything I need, and I go on my merry way home to change the belts. The alternator and water pump belts come off without much hassle as I figure out the adjustment systems, then comes the power steering belt.
I can not get the damned Power steering pump to move enough for me to change the belt! I managed to get some slack in the belt, and cut off the old one, but the pump will not move enough to allow the new belt onto the truck.
Is there a special technique? or should I just try removing the whole pump to do this? Any suggestions?
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 22nd, 2003, 03:28 PM
Hans's Avatar
Hans
Hans Haase
Got the sucker finally
Well, got the damn thing on finally. Involved removing the front bracket that attaches the power steering pump to the water pump, taking the PS pump off the mounts and that finally gave enough room to get the belt over it.
Is this something that other people have run into? Or am I just a spaz?
-Hans
My oil line fix
Old March 13th, 2009, 10:12 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Reviving an old thread here.
I am having the same issue replacing the PS belt. Whoever designed this thing was an idiot (and my entire apartment complex now knows it too beacause of my cursing)... there just isn't enough room to swivel that pump around.
Anyone figure out a better why to change this belt in the 5+ years since this thread was started? If not I guess I'll just try dismounting the pump...
Old March 13th, 2009, 11:23 AM
I took the pully off the pump and then put the belt on, and then put the pully back on.
But I am a hack.
Ron
Old March 13th, 2009, 11:38 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Hmm... that sounds like a good idea. Is taking the pulley off as simple as it sounds? Just take the three bolts off the front?
Old March 13th, 2009, 12:50 PM
Yes.
Ron
Old March 13th, 2009, 01:42 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Well that's good news then. Thanks Ron! I'll give it a try.
Old March 13th, 2009, 02:25 PM
I had to do this when I replaced my water pump a few weeks ago. IIRC that plus the adjustment got it to fit.
Old October 8th, 2009, 08:13 AM
phoenix37's Avatar
phoenix37
john
How to tighten this belt?! I cant get my pump to move at all. Loosened the bolt on the bracket but no movement. I took the pulley off to replace it but cant get it tight. What am i missing? Do i need to crow bar this thing to budge it?
Old October 8th, 2009, 10:41 AM
phoenix37's Avatar
phoenix37
john
Anybody? Im right in the middle of this and need to get the truck back on the road today.
Old October 8th, 2009, 12:18 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I think you just use a pry bar (huge flathead screwdriver w angled head) to put tension on it as you tighten it up, you might need someone to apply tension on the prybar as you tighten the bolts.
Robert Deniro
Old October 8th, 2009, 12:37 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
But I am a hack.
Ron
That is the way we hacks here at ECR do it too.
Email:
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
I did just as Neil described but used a big open-ended wrench. I think... I may have had someone hold tension on it while I tightened the bolts.
Old October 8th, 2009, 01:05 PM
phoenix37's Avatar
phoenix37
john
ok thats what i started to do and then i thought for sure i was going to break something. So Im glad i asked.
90, d-90
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
