Trouble after a deep water ,V-8 - Defender Source
Old February 17th, 2012, 07:45 PM
Brent Nevin
Brent Nevin
95 st
95 NAS st
A water crossing was much deeper than I thought the other day..
got through it ok but...
Now I seem to be running rich.., backfiring in first and second,trembles when I give her more than 3/4 throttle "loss of power". and had a glowing red hot Cat converter. I cleaned the distributer making sure it wasnt wet inside, no luck. Im also smelling a much stronger than normal fuel smell coming from the exhaust.. Any quick ideas to the culprit before I start tearing into her tommorow? thinking I messed up the timing some how?
saving up for a diesel...
thanks guys,
Brent
Old February 17th, 2012, 08:06 PM
LRover's Avatar
LRover
J. Michael McCaig
Check to see if water got into the storage compartment under the passenger seat where the ECU is located...it may be wet.
Old February 17th, 2012, 08:12 PM
Diesel this diesel that.
I wonder if hitting cold water with hot catalytic converters damaged the guts? I did this once on a Z71.
Old February 17th, 2012, 08:16 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Stupid question but did you pull the leads off the plugs as well and make sure those aren't wet?
Old February 17th, 2012, 09:14 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Red hot cats usually point to the guts chucking it in.
Old February 17th, 2012, 09:39 PM
The ECU got wet or an O2 got wet. Take the ECU out and dry it out to start.
water
Deep Water wading Uncle Douglas Misc. Chit-Chat 17 February 25th, 2008 08:50 PM
If I go near deep water again,,,,,,,,,,,, Mike Hippert Misc. Chit-Chat 12 June 22nd, 2005 03:20 PM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
deep water fording rover4x4 Misc. Chit-Chat 8 October 28th, 2003 08:56 AM
