trouble accessing steering box adjustment screw on '88 D90 2.5TD - Defender Source
Old March 13th, 2016, 04:48 PM
ITALY2AMERICA
Zachary Hoyt
88 D90 CSW
Second issue I had today was in accessing the adjustment screw on my steering box. I thought I'd be able to access it if I took the plenum out, only to find out that it does not have enough clearance to get an allen wrench in the head. The workshop manuals make it seem like you should be able to access it without removing anything, but i have hoses and I believe the air filter mounting bracket in the way...
Old March 13th, 2016, 05:19 PM
If I'm understand correctly, cut a small piece of the Allen wrench and use a open end spanner to turn it if room is an issue. Necessity is the mother of invention.
Old March 13th, 2016, 05:21 PM
ITALY2AMERICA
Zachary Hoyt
88 D90 CSW
you are a savage... and I like it. No other way around this? anyone else had to do the same thing?
90, ac, d90
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
2.5td wont start unless pump bleed screw open msomers Defender Technical Discussions 11 July 2nd, 2013 02:53 PM
Steering box replacement & adjustment 16kpsi Defender Technical Discussions 1 January 17th, 2011 06:38 PM
problems accessing website? Caribsurf Support & Suggestions 12 December 2nd, 2007 12:49 PM
