Trinary Pressure Switch - Defender Source
Old June 27th, 2012, 09:01 PM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
Looking to see if anyone knows what the Trinary Pressure Switch would look like for a 94 Defender 90 NAS? I've found a bunch on Ebay but not too sure which ones would work. RN doesn't have them and local dealer didn't either. and if anyone has one for sale I've also got this posted in the wanted section.
cheers
chad
Old June 27th, 2012, 09:22 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
The two PN's I find are 8510066 & STC3976, so maybe a bit of googling will find an image.
No idea if they're the ones for a '94, but they are the only 2 in microcat for Defender.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 27th, 2012, 09:40 PM
any aftermarket AC shop should be able to hook you up ... it's not special ... the only thing is you may need to change the electrical connector. While you are at it change the drier ..
Old June 27th, 2012, 09:54 PM
triple9music
Chad Davis
1984 Defender 90
thanks Tom and Jason! good advice and info! googled those parts #s and found a thread on here that says the 8510066 part is no longer available. Other one didn't really produce anything I could figure out. EU parts catalogs in german.
switch, trinary
Trinary Pressure Switch triple9music Wanted 0 June 27th, 2012 08:28 PM
WTB- a/c trinary pressure switch '97 d90 bamanuke Wanted 0 March 19th, 2010 08:32 PM
