trimming fuel tank - Defender Source
Old August 3rd, 2014, 03:34 PM
mattarm's Avatar
mattarm
Matt
1993 D110
trimming fuel tank
As a result of some rear cross member repair, I now have a slight clearance issue in fitting the fuel tank. My question is can I trim the mounting "tabs" for the tank where the upper an lower sandwich together, marked on the attached pic in order to shorten the overall tank length without compromising the integrity of the tank? I know that I can use a few spacers to lower the tank by an inch or so, but my preference would be to have it in the original location. Thoughts?
Old August 3rd, 2014, 03:42 PM
the rover shop
shayne young
If you look closely you will be able to see the line aroind the tank whee it is crimp welded together.. As long as you don't go through that line you shouldn't have a problem.. I had to carry out the same modification on mine too.. And I've beat the snot out of my truck for years without a problem..
Old August 3rd, 2014, 04:07 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Thanks Shayne. Always good to know that someone has been here before with good results.
fuel, fuel tank
Aluminum traction sand mats and aux fuel tank / water tank jonathon For Sale - Parts 7 December 11th, 2012 03:14 PM
Defender 90 Fuel tank - Disco 97 / 98 tank thpsmr Defender Technical Discussions 15 December 9th, 2011 11:44 AM
Diesel fuel tank vs. Gas tank Tyler Wirken Defender Technical Discussions 9 January 28th, 2010 07:25 AM
Fender Flare trimming? BradforD90 Misc. Chit-Chat 6 March 2nd, 2009 12:16 PM
Preferred tool for flare trimming? KevinNY Defender Technical Discussions 6 February 26th, 2007 09:33 PM
