Tricks to fitting lower rad hose 300tdi - Defender Source
Old March 20th, 2014, 03:08 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I am in the process of refitting my lower radiator hose. I can't seem to get the hose onto the lower portion of the radiator. This is the one piece hose that connects half the cooling system it seems.
Anyone have any advice on how to get the hose back on? I don't want to pull the intercooler, condenser, etc to get the radiator loose enough to fit it. Shouldn't it just go on the fitting?
Alex
Old March 20th, 2014, 03:20 PM
Have you lubed your hose?
Old March 20th, 2014, 03:25 PM
John,
This is a family friendly website. What he does in the privacy of his own garage is his own business.
Old March 20th, 2014, 03:48 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Originally Posted by javelinadave View Post
John,
This is a family friendly website. What SHE does in the privacy of HER own garage is her own business.
Fixed it for you
Old March 20th, 2014, 03:52 PM
Thanks Dave! I stand corrected, sorry Alexandra.
Old March 20th, 2014, 04:16 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I didn't lube my hose. I just shoved it in, with brute force.
Old March 24th, 2014, 01:59 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
We need more girls like this on this board
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old March 24th, 2014, 02:20 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Ladies.
Old March 24th, 2014, 02:26 PM
For rubber hoses use rubbing alcohol as a lube. It evaporates with no residue and makes hoses slide on easily. This is a trick I learned for putting hand grips on MTB handlebars.
Old March 24th, 2014, 03:23 PM
I've had that not evaporate on MTB bars because it ended up sealing so well. I used compressed air on my gf's bike.
For cooling system hoses, I always use silicone spray.
Old March 24th, 2014, 06:37 PM
Hand sanitizer works well, in the old days i used hairspray (what is that? )
Old March 24th, 2014, 08:35 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Hairspray works wonders on keeping intercooler couplers attached in high boost levels.
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
300tdi, tdi
Lower rad hose heater Naplm00 Defender Technical Discussions 3 November 17th, 2011 09:15 AM
Lower radiator hose pipe crushed? 950rider Defender Technical Discussions 2 April 3rd, 2011 06:46 PM
Lower radiator hose diameter and block heater aosias Defender Technical Discussions 16 February 10th, 2011 01:07 PM
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
