transmission/transfer case fluid - Defender Source
Old March 2nd, 2010, 06:37 PM
bjf's Avatar
bjf
barry f
94 ST #395
This may be stupid as I only did it once. I remember pulling a plug under the truck draining the transmission and refilling with redline. Now I am about to do that input gear and I was wondering, is the transmission and the transfer case filled with different fluid? If so where is the transfer case plugs? Is it possible in my infinite wisdom when I changed my tranny fluid I really did the transfer case with redline?
Old March 2nd, 2010, 06:43 PM
Transfer case uses regular gear oil. 80W-90 or 75W90. Drain is on bottom, small hex head...... Fill/Level is on back next to parking brake.
Old March 2nd, 2010, 06:49 PM
bjf's Avatar
bjf
barry f
94 ST #395
How much does it take? Do you need a pump for that too?
What would happen if you put redline in transfer case?
To change input gear do you need to drain both?
------ Follow up post added March 2nd, 2010 04:03 PM ------
Just realized for input gear it is transfer case that should be drained. So just regular oil?
How much and what?
Old March 2nd, 2010, 07:21 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
if you are doing the gear, you just have to do the t-case.. plug on the bottom pan. Filler on the rear near the parking brake. Use a 1/2 breaker bar to open that. It takes 2 qts.. I would use any good synthetic 90wt gear lube. Red line or royal purple are good ones.. Oh and you do not have to pump it in. Just pour it in the filler plug or fill it before you put the input gear in.
Legend in My Own Mind.
Old March 2nd, 2010, 08:20 PM
Pour in works but its a little messy. I like to jack it up on the DS so I can get a little more in the transfer case.
Old March 2nd, 2010, 08:25 PM
you do not need to drain anything to change the input gear because the oil level is below the level of the PTO cover opening.
Old March 2nd, 2010, 08:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ah but shouldn't I change it anyway?
Old March 2nd, 2010, 09:38 PM
Sure, but you don't have to.
Old March 2nd, 2010, 10:02 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Check it before you change it. Last time i changed
it i felt sorry. The damn thing was like new.
I use Motul Gear 300 (synthetic 75W90).
- Charles Eames
Old March 2nd, 2010, 10:14 PM
It does not get black, but it does lose it sheer ability. I use synthetic and change at 30k.
Old March 2nd, 2010, 10:15 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I always figured that good old castrol 80 90 was fine. I also thought that all cars that have a fill and drain operate the same. Pour it in and it is full when it starts to come out the fill plug. That is why it is made that way. Possibly over thinking an easy and cheap task. Maybe synthetic is better in the long haul.
Thats my story and I'm sticking to it.
And hay
And I love you too
Old March 2nd, 2010, 10:37 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah thinking about trying the royal purple stuff. Looks decent enough.
Old March 3rd, 2010, 07:41 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I was going to say that but i figured that if he is changing the gear for some reason, there prob was a problem and there is some crap in the oil from the worn out gear or inner splines... Good time to change it.
Old March 3rd, 2010, 01:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
How do I flush the fluid?
Old March 3rd, 2010, 03:32 PM
hook a water hose up to the filler plug and let it run for a half hour
Old March 3rd, 2010, 04:59 PM
bjf's Avatar
bjf
barry f
94 ST #395
come on!! that has to be a joke
Old March 3rd, 2010, 06:38 PM
specops1526's Avatar
specops1526
Beluga '97 90
Come on now, if this is real advice, ok...but if it could harm someone's truck, don't post it. Everyone jokes around here, but, if you do, at least make it obvious. My first thought was that water in the tcase will wreck it, at least that's what my mechanic told me probably trashed one of my old ones...
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old March 3rd, 2010, 06:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
For shame. Ruin my truck damn you. Unless you are talking about putting a hose in Horsey's mouth and letting it run for a half hour I don't want to hear it.
Old March 3rd, 2010, 08:19 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I used to flush my SIII transmission case with diesel.
- Charles Eames
Old March 3rd, 2010, 09:59 PM
phoenix37's Avatar
phoenix37
john
Now you want to water board Josh? When will this end?
transfer case, transmission
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
Rover Expedition Case w/ 4 walkie talkies jack frisch For Sale - Parts 0 February 27th, 2005 03:24 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
