Transmission/T-Case/Clutch/Pressure Plate bad? - Defender Source
Old March 25th, 2013, 06:06 PM
naeirie's Avatar
naeirie
Nilo Enerio
95 D90 ST #2571
So my 95 D90 will not move. I was at a stop. Put it in first gear released clutch, heard a clunk and the car will not move. I can shift to all 5 gears including reverse while the engine is running without pushing the clutch in. When I do put the clutch in, put in gear and release the clutch I get a rattling noise. Anyway,iIt is at the shop now. Wanted to get opinions on what might be the problem. The clutch is still original never been replace and my D90 is pushing 200k miles.
Nilo
Old March 25th, 2013, 06:16 PM
Sounds like a stripped transmission output shaft. Where does the rattle come from ?
Guessing you made sure the tcase didn't pop out of gear.
Old March 25th, 2013, 06:32 PM
naeirie's Avatar
naeirie
Nilo Enerio
95 D90 ST #2571
I am not sure. I can't tell where it is coming from.
Old March 25th, 2013, 06:37 PM
First is to make sure it is not in an axle. Engage the diff lock and see if you move.
Second, remove PTO cover and see if the gearbox output shaft is turning.
Basically, YOU have to diagnose the fault.
clutch, transmission
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Fuel tank skid plate GeoParth Defender Technical Discussions 53 June 25th, 2006 03:21 PM
License plate Mike Hippert Misc. Chit-Chat 27 September 16th, 2004 04:07 PM
front plate mounting souza Defender Technical Discussions 10 August 27th, 2004 11:12 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
