Transmission stuff - Defender Source
Old August 27th, 2016, 06:28 PM
SARTech
P. Barber
1989/Defender 90
Transmission stuff
Is this bad?
Looks like time for a gearbox rebuild. Anyone done that themselves?
ID:	156534   Click image for larger version
Old August 27th, 2016, 06:29 PM
No image...
Old August 27th, 2016, 06:41 PM
SARTech
P. Barber
1989/Defender 90
Originally Posted by Jymmiejamz View Post
No image...
I think i fixed the images, sorry.
Old August 27th, 2016, 06:42 PM
Works now.
Do you have any symptoms?
Old August 27th, 2016, 06:50 PM
SARTech
P. Barber
1989/Defender 90
No image...
Initially had a 'not good' noise in 3rd and 5th. Replaced the fluid and now it quite, no symptoms or noise.
I just purchased the rig, drove it home about 100 miles. at about 30 miles from home the trany started making noise. When I got it home I drained it and it was almost empty. I refilled it and drove it around some, the noise went away after about 20-30 miles and I noted a big oil leak. Found the source of the lead, there was a bolt missing from the top housing that the transferase selected lever goes into. I installed a new bolt, drained and refilled the tray. The pictures are from the second drain/refill. At present, no leaks or noise.
Old August 27th, 2016, 08:18 PM
Honestly, it's far less hassle to just order one from Ashcroft. I can certainly do a transmission rebuild by myself, but I won't ever do another cz they make it such a no-brainer.
Old August 27th, 2016, 08:42 PM
Contractor's Avatar
Contractor
Will
1969 IIA
If the thing shifts fine and does not make a bunch of noise, I would not mess with it until something blew up.
That's me.
Old August 27th, 2016, 08:56 PM
Grover's Avatar
Grover
Originally Posted by SARTech View Post
Is this bad?
What transmission do you have?
Old August 27th, 2016, 09:37 PM
That looks like a ground up synchro hub. I would clean it out and keep running it as I don't see any chunks.
Old August 27th, 2016, 10:22 PM
SARTech
P. Barber
1989/Defender 90
LT77,
1989 Defender 90.
Old August 27th, 2016, 10:23 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
"That looks like a ground up synchro hub. I would clean it out and keep running it as I don't see any chunks."
So what would you run in it and for how long to make things settle out in the bottom ?
Maybe something thin like ATF or kerosene for a couple of slow miles in the neighborhood?
Old August 27th, 2016, 10:25 PM
SARTech
P. Barber
1989/Defender 90
No big chunks, some soft flattened metal flakes.
------ Follow up post added August 27th, 2016 08:32 PM ------
That's me.
Thanks, I think I'm leaning that way. If it aint totally broke why fix it?
Old August 27th, 2016, 10:43 PM
LT77s original spec was Type F ATF. I would buy some cheap stuff at Walmart and run it for 100 miles or so (maybe less depending on how much cheap ATF I had on hand) and drain and then repeat and then switch over to Redline MTL once you get no more crap. I would go easy on it until I was sure it was clean.
Old August 28th, 2016, 03:34 AM
What he says. You may also be a victim of PO maintenance negligence. I'd replace the other fluids as well etc.
Old August 28th, 2016, 07:28 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You didn't mention if you have to depend on this for transportation.
I would order an R380 replacement from Ashcroft and have it on hand so when the LT77 fails you can swap it out at the next available time slot, but that's just how I operate.
Also note a failing clutch or badly adjusted clutch can cause you to grind gears which may have been the cause of the synchros being chewed to shreds.
RDavisinVA
Old August 28th, 2016, 07:36 AM
Contractor's Avatar
Contractor
Will
1969 IIA
Fill it up with either Penzoil Synchromesh or Redline. The Penzoil is less expensive, easy to find locally and makes my LT77 shift better than with the Redline.
Old August 28th, 2016, 09:59 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
SACRILEGE! Everybody here believes Redline MTL is what pours out of the Holy Grail!
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old August 28th, 2016, 06:55 PM
Grover's Avatar
Grover
Is that a filter in the first pic?
Does the r380 have a filter too?
Old August 28th, 2016, 07:25 PM
The act of rebuilding a gearbox isn't difficult.
The question is whether or not you know which parts need to replaced and which can be kept. With the amount of grey metal on that magnet, you're going to need to replace more than just the synchros, shift forks, bearings, and oil pump.
Old August 28th, 2016, 08:06 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
here
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
transmission
searching for engine and transmission.1988 110 3.5V8 and LT85 transmission Edmond Defender Technical Discussions 6 May 20th, 2015 02:23 AM
Big pile of LHD stuff (maybe) and Puma stuff atlcruiser The Vendors Loft 4 March 5th, 2013 07:16 AM
some RRC/90 stuff, some DII stuff. ukoffroad For Sale - Parts 28 July 8th, 2012 12:29 PM
B and C pillar and other stuff and stuff for trade bstraw Wanted 2 January 10th, 2007 11:11 AM
do 1997 california d90s have extra smog stuff? tomken Defender Technical Discussions 3 January 4th, 2004 02:55 AM
