Transmission Shifting Issues - Defender Source
Old April 18th, 2015, 05:17 PM
Jedelmann's Avatar
Jedelmann
John Edelmann
1994 Defender #1194
I have a 1994 NAS D90 with 93K miles and suddenly I'm having issues with finding/shifting into 3rd gear and reverse. It's like the entire transmission has changed its position slightly and when I shift into 3rd and 5th, the gear shifter hits the dash (it never did before). Also, there's a lot more play in the gear shifter. Any thoughts as to the problem? Thanks in advance.
84 110 Dormobile
94 D90 ST
14 RRS
Old April 18th, 2015, 05:57 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
There is a set screw that allows for throw, it probably backed out, if this is an all of a sudden thing.
Old April 18th, 2015, 09:33 PM
Jedelmann's Avatar
Jedelmann
John Edelmann
1994 Defender #1194
Thanks, guys. I will check out your suggestions and report back.
84 110 Dormobile
94 D90 ST
14 RRS
Old April 23rd, 2015, 10:50 PM
Jedelmann's Avatar
Jedelmann
John Edelmann
1994 Defender #1194
Guys,
Looks like it was the set screw...have to replace the gasket and we'll be rolling tomorrow. Thanks for your advice.
84 110 Dormobile
94 D90 ST
14 RRS
transmission
'97 D90 transmission shifting problem ember Defender Technical Discussions 14 December 14th, 2012 09:42 AM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
97 D-90 Auto Transmission Shifting at Higher RPM parkcity4x4classic Defender Technical Discussions 7 October 30th, 2006 05:35 PM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
Shuddering when shifting... mlw911 Defender Technical Discussions 1 August 26th, 2004 09:18 AM
