Transmission replacement questions - Defender Source
Old July 26th, 2006, 09:16 PM
I'm about to replace the transmission in my 94 D90. It is currently an auto box out of a '94 disco I am told.
1. If I go used, whats the newest model I can get to mate up? Thinking as new as possible this will ensure a chance at the lowest mileage. I think what I have is an 4HP22 which goes up to '95 discoveries. Would a 4HP24 (96-02 discos) work?
2. What else should I do while I have it out? I assume replace the rear main engine seal, and I plan on cleaning and lining the undercarriage with some sort of rust prevention and sound inhibitor. Any other suggestions?
3. Lastly any opinions on used vs rebuilt? I can get a used one for as low as $400 with about 4 hours of driving to get it (and I guess I'll need a filter kit), or about $1400 shipped for a rebuilt one.
thanks
charles
Old August 1st, 2006, 12:16 AM
Dang no bites?
Well, I ended up ordering a rebuilt one. We'll see how it goes.
Loic came over on saturday and helped me pull the transmission - it really helped having a second pair of hands and we made quick work of it. Thanks Loic!
I do have a couple of questions now that it's out (yes always questions).
1. Can the engine rear main seal be replaced without dismantling the engine? The service manual leads you to believe you can't.
2. If yes, does the flex plate on the flywheel need to come off before I can pull the flywheel, or can I just yank the flywheel without removing it? Anything else I should know? :D
3. What's this switch that wasn't wired on my transfer case?
http://lhsw.com/gallery/stuff/DSC01508
4. I hope this wasnt the source of my problems, but the kickdown cable grommet is broken. Any idea of a rebuild will come with this or do I have to order one? if I need to order one, will it be obvious how to remove it once I pull the pan?
http://lhsw.com/gallery/stuff/DSC01509
It looks like I can pre-assemble the transmission and transfer case before putting it in place which should make that a lot easier. This assumes I can get a helping hand again
thanks
charles
ac, transmission
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
Lifting engine and transmission together?? cbass Defender Technical Discussions 5 November 7th, 2005 06:23 AM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
94 discovery automatice transmission capacity cgalpin Defender Technical Discussions 4 August 26th, 2004 10:57 AM
Transmission Replacement Options??? JRowe Defender Technical Discussions 17 October 14th, 2003 10:46 PM
